having trouble going on reverse
Old May 16, 2006 | 08:08 PM
VRRX8's Avatar
Exclamation having trouble going on reverse
just got my 8 monday and i cant get use to the reverse, sometimes it grinds and wont go in, what is the easiest way or the right way to put it in reverse??
Old May 16, 2006 | 08:14 PM
FABRO's Avatar
Registered Ricer
are you pushing the **** down, while you are shifting in reverse?
Old May 16, 2006 | 08:15 PM
VRRX8's Avatar
yes i push it down
Old May 16, 2006 | 08:16 PM
dillsrotary's Avatar
jersey fresh
is it new or used? and does it stay in reverse once its in gear?
zoom44's Avatar
stop. go into neutral. when engine is at idle press clutch in press shifter vertically down. while holding shifter down move shifter to the rigth and then back
Old May 16, 2006 | 08:25 PM
VRRX8's Avatar
it is used with 14k miles, and zoom44, thats what i do, also somebody told me something about double clutching before putting it in reverse, does that matter??
VRRX8's Avatar
also, yes it does stay in reverse
Old May 16, 2006 | 08:28 PM
mysql101's Avatar
the reverse is sometimes tricky to get into, it will grind if you have it in partially. Try leaving the car turned off, and with the clutch fully depressed, going into reverse a few times. Listen for the noises it makes and you should be able to hear when it's in properly.
Old May 16, 2006 | 08:37 PM
chizzer337's Avatar
I got my 8 with 17k miles and i had the same problem. I was doing everything right, but it was grinding and I had to slam it into gear. I took it to Mazda, explained the problem, promblem solved
Old May 16, 2006 | 08:42 PM
jersey fresh
so..... what was the problem??
Old May 16, 2006 | 08:48 PM
juikster's Avatar
Im 8 drifting on a budget
one of a few problems of the 6 sp. I also have to allow the warm up period to have a smooth engaging of the reverse ...its not that I'm doing the downshift wrong,its just the fricking cars tranny has to warm up to temp...my bad
Old May 16, 2006 | 08:49 PM
mysql101's Avatar
Even driving in forward, my car had to warm up before it shifted nicely. This was true stock and with redline transmission/diff oils. When I switched to royal purple, the car drove like it was warmed up even when it was ice cold. Well worth the investment of 4 bottles of max gear.
Old May 16, 2006 | 08:55 PM
yiksing's Avatar
the giant tastetickles
2 clicks sound when the reverse gear is truly in.
Old May 16, 2006 | 09:06 PM
NgoRX8's Avatar
^yup
i think it's time to take it to the dealer
Old May 16, 2006 | 09:11 PM
aggietiff28's Avatar
Mean Green Keeny Machine
Try shifting into first gear and inching forward just a tiny bit, then shifting into reverse. Works for me every time that I can't get it into reverse. That actually works on just about any car, but the 8 has been the toughest manual tranny to hit reverse in that I have had so far.
Old May 16, 2006 | 09:23 PM
REMillers's Avatar
I use to have the same problem when I first bought the car for maybe the first 10k miles.
Sometimes when putting it into reverse it would not fully engage and grind. Would have to put it back into reverse. I finally just started putting it into reverse twice. So put it in, back to neutral then back into reverse before letting the clutch out. Doing that never had a issue and currently it seems fine.
Old May 16, 2006 | 10:41 PM
what he said, but you really just have to put it into first gear.... then go to rev.
Old May 16, 2006 | 11:33 PM
LOL, what SHE said....BTW, it doesnt work for me if I just put it in first and then back into reverse. I actually have to engage first before it will go into reverse sometimes. This doesn't happen all the time, but I would say most of the time.
Old May 17, 2006 | 12:31 AM
daisuke's Avatar
rotorized!!!
this is normal, all cars with a manual box do this sometimes, it comes from the gear not being syncronized.
step on the clutch, try to put it in, if it grinds then re-clutch, take it out and let go of the clutch, then (re-)re-clutch and put the gear in. but the forwards and then reverse works too if you have the space to do it in.
Old May 17, 2006 | 07:20 AM
VRRX8's Avatar
well that never hapend to me, i will try everything, and see what happends
Old May 17, 2006 | 06:50 PM
stickman's Avatar
Sit backwards and put it in first.
theblinkof
Oct 4, 2023 05:24 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
superROB23
Sep 4, 2015 01:22 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
