View Full Version : gas mileage vs. oil level...
djseto
05-15-2006, 05:02 PM
Maybe its just coincedence, but I have noticed that as I get lower on oil, my gas mileage gets better. I dont see mechanically how this would be possible though. I was getting like 20+ mpg making the same commute I always do on my last tank and when I went to check the oil, I was a tad above the low oil level line. I added more oil to bring the level back to the top of the dipstick level and already, judging by mileage and fuel tank level, I am getting worse mileage. This isnt the first time this has happened, I just figured it was a fluke. I use the 'B' Trip meter to monitor the miles between when I add oil. Its always right around 1000-1100 miles. Whenever I get near the 800+mile mark, I seem to get better gas mileage. Thoughts?
Wildmatt
05-15-2006, 09:05 PM
The gas gage is not very accurate. Unless you can verify via the trip odometer and actual gas gallons filled, then it is probably just not true.
Vertigo-1
05-15-2006, 09:58 PM
I sort of noticed this too and wondered the same thing, so you're not alone. Haven't actually tried to test it though.
alcimedes
05-15-2006, 10:20 PM
Hmm, I'll try and keep an eye on this to see if I notice anything.
yiksing
05-15-2006, 10:23 PM
This is actually true to some point, I overfilled almost 0.7 litres of oil and the mileage sucked real bad. Drove the car until it was 0.25 litre under full mark, top up fuel tank and my mileage was slightly higher.
djseto
05-16-2006, 05:09 PM
does anyone have a technical explanation for this?
i know the gauge isnt very accurate, but at the same time I know that when I reach the half tank mark, good mileage is when I have about 120-140 miles on the OD. When I hit a half tank and I get 100 miles, I know I am getting bad mileage. It may not be accurate compared to whats physicall there, but its level of inaccuracy is consistent for the most part.
Georgia8er
05-16-2006, 06:55 PM
I can't see how oil level could affect gas mileage. In piston engines if you way overfill you can get foaming, but that usually results in a blown engine. With the system an RX-8 uses I don't think there could be any foaming, and the ECU doesn't know the oil level either. Might want to do it a statistically significant number of times and be sure.
loco4rx8
05-16-2006, 09:17 PM
I don't know if this represents any kind of correlation between oil level and gas mileage, but I have a spreadsheet of my gas mileage, and every single time I get an oil change, my mileage drops about 1 mpg. After about 1000 miles or so, it goes back up to where it normally is. This never fails.
Detrich
05-17-2006, 01:41 AM
hmmm. now that you guys mention it, i've noticed this also and wasn't quite sure if i was being too sensitive about it... but, i guess it's not just me after all.
the last time i added oil it to get the dipstick to the full level (like the manual says to do every other fill-up), i noticed a drop in my mpg. am starting to think it might be better to add oil every 3 fill-ups instead, since the oil level on the dipstick never really gets dangerously close to low level. (it's usually about half way or more than half way between low & full every other fill-up.)
i think i'm going to do that this round and see if the mpg goes back up... let's all keep an eye on it. am very curious about this now...
iridearocket
05-17-2006, 10:35 AM
I calculate the gas mileage after most fill ups... I've found that some tanks can be reasonable and others are terrible. I always use the same gas and don't really drive differently enough to make that much difference. (one would imagine) I'm having a difficult time understanding how there can be so much variance.
That's very interesting that you think there may be some correlation to oil level. I'll pay more attention to this, but I don't burn excessive amounts of oil. I add about 1 liter every 2500mi.
I have calculated gas mileage when on the track and it is nearly double (70-80%) that of my usual road driving. With my previous car (non rotary) the mileage would only go up by 20-30% when racing around a circuit. These things are thirsty.
Brice-RX8
05-17-2006, 01:24 PM
Not following you on this one. Are you saying that you get better gas mileage on the track? You should be getting very bad mileage on a track running wide open.
iridearocket
05-17-2006, 02:13 PM
Sorry if I was not clear. My rotary seems to use ~70%+ more gas while givin' er the goose on the track. (as compated with driving the same car on the street) Whereas my previous volkswagen only seemed to guzzle 30% more fuel while tracking the car. (over street driving)
djseto
05-17-2006, 03:00 PM
I would contribute that to our ridiculously fun 9K redline. More revs = more gas
