Weight difference in rotors
Old May 12, 2006 | 10:42 AM
RX3+5's Avatar
Bullshit Detector
Has anyone weighed the difference in drilled rotors and stock?
TIA,
Vince
Old May 12, 2006 | 11:33 AM
expo1's Avatar
He's as bad as Can
Not drilled, but lighter http://forums.racingbrake.com/viewtopic.php?t=42
Weights on their other rotors http://www.racingbrake.com/MAZDA_RX8_s/235.htm
Old May 12, 2006 | 01:51 PM
RX3+5's Avatar
Bullshit Detector
That helps thanks!
Does anyone know anything more on some of the drilled?
TIA,
Vince
Old Jan 31, 2008 | 04:19 AM
rotaryPilot's Avatar
Well I cannot open the above links but I do not know if I will find answer to my question:
Does anybody knows what is the weight of OEM Front Rotors and OEM rear Rotors?
I ask because I am interested in some cheap ebay slotted/drilled rotors but I am believe that may be heavier than stock.
Old Jan 31, 2008 | 04:38 AM
front, 17lbs
rear, 12lbs
you will not lose enough weigh with drilling to make a difference..
and the weight of any rotor on ebay is a guess..
the project mu two piece rotors i have saved about 1.5 lbs per rotor..
and they were not cheap ebay units..
Old Jan 31, 2008 | 10:32 PM
SolarYellow510's Avatar
If your car is only getting autox miles, you can always have them turned down to minimum thickness.
You can also find other places to drill them yourself. Just do so uniformly so you don't affect the balance.
And of course, you are totally responsible for the structural integrity of any parts you modify yourself.
Or you could just go buy some two-piece rotors.
Old Feb 2, 2008 | 11:32 AM
Drilled roors have a tendency to over heat and cause micro fractures.
I would not go drilled.
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
patriotjj
Sep 13, 2015 08:09 AM
jackslao
Sep 8, 2015 01:50 PM
rxwilly8
Sep 2, 2015 02:42 PM
