Marin Mazda Hooked Me Up!
Old May 11, 2006 | 11:57 PM
ndrx8's Avatar
About two months ago I f'd up my stereo trying to install an AuxMod for my Sirius tuner. While I was trying to decide if I should look for a used one, go aftermarket, or bite the bullet and get a new one, my car died and was towed to Marin Mazda. They fixed a whole crap load of recalls (including battery, starter, control arm, airbag, heater core, etc) and fixed my stereo under warranty. Made my day!
Old May 12, 2006 | 03:23 AM
daisuke's Avatar
rotorized!!!
how are they for good deals on 8s? I'm on the central coast of california and the dealer here I'm sure is very bad at making any good deals since they're the only one for miles around.
Old May 12, 2006 | 09:43 AM
alnielsen's Avatar
The control arm and airbag were recalls. The rest were Technical Service Bulletins or TSB's. TSB's are not required to be done unless you are having a problem in that area. The control arm recall was probably just a check and nothing was replaced. You didn't mention anything about the gas tank recall.
Old May 12, 2006 | 09:52 AM
lesper4's Avatar
T-29 years and counting
thats the way customer experiance should always be, glad you had the chance to experiance it.
Old May 12, 2006 | 11:28 AM
ndrx8's Avatar
I'm not sure if they have good deals on 8s - I bought the car used from another (non-Mazda) dealer. This was my first service experience with them. Some of the recalls/TSBs had probably been done on this car, but some hadn't. They actually replaced the control arm according to my service print-out. They also knew I'd been messing around with the stereo, and they still got it fixed under warranty.
Old May 12, 2006 | 03:08 PM
beachdog's Avatar
ndrx8, I was thinking about buying an auxmod or similar. How exactly did you mess up the stereo? Did the auxmod cause the problem?
Old May 12, 2006 | 09:49 PM
ndrx8's Avatar
There's a post here somewhere, but basically, the plan was to take the headunit out of the car (the write-up said the battery didn't need to be disconnected for this). I couldn't get all the wiring harnesses off, but I got the HU out far enough so that I could access Auxmod/tape input slot. Must have fried something while putting it in. I'd definitely take the two minutes to disconnect the battery next time I do anything with the electrical system.
Paul_Y
Sep 21, 2015 02:23 PM
czr
Sep 13, 2015 11:37 AM
just1jack
Sep 9, 2015 04:45 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
