RX-8 Rotor and RX-7 Rotor
Old May 11, 2006 | 08:41 AM
LostAngel's Avatar
Hey, I was just wondering...are the dimensions of the rotor in the RX-8 the same as the RX-7? Also, I have looked and haven't found anything...but does anyone know where I can get a blueprint of the rotor itself for the 8?
Old May 11, 2006 | 10:11 AM
rotarygod's Avatar
The rotors themselves are the same physical size. There are some diferences with the seals though. The Renesis rotors have a cutoff seal in between the side seals and the oil control rings that the 13B's do not have. The shape and size of the seals is also different between rotors. Due to this fact the RX-8 rotor can be used in an RX-7 but not the other way around. You'll just have to trust me on that one. The casting thickness of the RX-8 rotors is also thinner than the 13B which makes them less strong but lighter. I'm not sure where you can get any dimensional drawings. I'll start digging.
Old May 11, 2006 | 10:54 AM
LostAngel's Avatar
Thank you very much rotarygod, I didn't really know the differences and would love if you could find the blueprints.
Old May 11, 2006 | 03:13 PM
dmorales's Avatar
Spin Triangles! Spin!
If you find them pm, plz I would like to see them also.
________
HotLady
Old May 11, 2006 | 07:47 PM
daisuke's Avatar
rotorized!!!
me three
Old May 12, 2006 | 12:30 AM
rotarygod's Avatar
One thing I can tell you that hardly anyone knows is that the physical shape of the Renesis rotors is different than the 13B rotors. The housing shape is still the same though. The thing that counts is that the apex seals all line up in the same place and that the rotor never physically touches the housings. The shape isn't that much off and you can really only tell by holding them directly against each other. The Renesis rotors are less "rounded".
Old May 12, 2006 | 01:02 AM
takahashi's Avatar
Chamber is also different?
I have an RX-7 magazine talking 3 different rotor from 13BT 13B -REW and 13B-MSP... I will dig that out too
Old May 12, 2006 | 06:37 AM
LostAngel's Avatar
I never knew that....thanks rotarygod! In all the demos of the renesis, it looked like the rotor DID touch the housing.
Old May 12, 2006 | 07:59 AM
Aseras's Avatar
the apex seals touch, but the rotor is still a MM or so away
Old May 12, 2006 | 08:23 AM
LostAngel's Avatar
Yeah, I knew the apex seals touched...just didn't know the rotors didn't.
Old May 12, 2006 | 10:44 AM
Icemark's Avatar
There is also a chamfer on the leading edges of the rotors on the Renisis motors, which was not found on any RX-7 13B motors
bbostic5
Feb 24, 2019 05:32 PM
Gerald Nunn
Canada Forum
Aug 25, 2015 12:15 AM
Nisaja
Far East/Asia
Aug 20, 2015 11:51 AM
RXeckless
Aug 16, 2015 12:51 PM
