normal oil pressure?
Old May 8, 2006 | 03:31 PM
olddragger's Avatar
Question normal oil pressure?
Ok the manuel says that the oil pressure when the oil is at 212F should be 50.8 at 3Krpms. Since I have installed my gauges I havent had the oppitunity to get my oil temps that high(max high for me so far is 180F) but my oil pressure is around 44-46 at 3 K. Now i am picking my pressure up through a RB filter mounted sender site. Does that make up for this differance? The factory is probably registering from the electrical site below the filter. Thoughts?
olddragger
Old May 8, 2006 | 11:49 PM
oil pressure is not anywhere near as critical on a rotary as a piston engine, I wouldn't sweat that small difference. It would have been nice if they had listed a minimum allowable spec though ... kind of strange that they only list one point rather than a range or max/min
Old May 9, 2006 | 06:12 PM
r0tor's Avatar
oil pressure is going to depend heavily both on rpm and temperature
i also haven't looked at RB's adapter, but does is measure on the in or out of the filter (will make a few psi difference)
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
