ECU will increase HP - Pre programmed
Old May 5, 2006 | 02:02 PM
puch96's Avatar
Exclamation ECU will increase HP - Pre programmed
All,,,
I heard rummors that the 8's ECU will eventually excecute a different software code once a centain millage mark (typically 15k to 20k) is reached..... The ECU will unleash the full rated HP (238-250 HP) originally intended.
It is said that the ECU is pre-programed this way on purpose in order to provide a good break in period for the engine by limiting the output power when the engine is new.....
Any of you heard something like this before???
Old May 5, 2006 | 02:05 PM
zoom44's Avatar
heard it- rumour started on this site 3 years ago- its just that a rumour. doesnt happen.
Old May 5, 2006 | 02:07 PM
mikeb's Avatar
100% Italian
some people noticed a difference at 15 or 20k miles
i dont believe it though
Old May 5, 2006 | 02:13 PM
haha, good one...
snkpkp's Avatar
thats because thats when the engine gets well broken in. i have a JDM 247hp and it seems faster now than two years ago.but i don think it increased any hp. heck it does not even feel its 247 hp. And I own a evo ix and a 350z and honestly the rx8 does not feel it has 247hp but it drives so much better than either of the two. Although the evo ix is a whole different breed so cant really compare with that.....
Old May 5, 2006 | 02:14 PM
DailyDriver2k5's Avatar
The Prototype
I could be wrong....but i thought this was mentioned in a article that had a long term review of the 8, possibly R&T, Motortrend, etc. But i thought i read that they said after so many miles, they never said specifically , that there 8 was a tad bit faster then when they took ownership of it new.
Old May 5, 2006 | 02:20 PM
snkpkp's Avatar
its probably motor trend i remember going through it too...but they said it felt faster, just like how ppl feel when their cars past 15-20k miles......nothing abt ecu i think. but i may be wrong.
Old May 5, 2006 | 02:25 PM
staticlag's Avatar
The Professor
23k miles, doesn't feel faster.
Old May 5, 2006 | 02:27 PM
snkpkp's Avatar
"feels" faster doesnt mean it "is" faster
Old May 5, 2006 | 02:37 PM
Glyphon's Avatar
脾臓が痛みました
car and driver
http://www.caranddriver.com/longroad...x-8-page4.html
Performance new 40,000
Zero to 60 mph 6.6 sec 5.9 sec
Zero to 100 mph 17.5 sec 16.0 sec
Zero to 130 mph 36.6 sec 34.8 sec
Street start, 5-60 mph 7.4 sec 7.2 sec
Standing 1/4-mile 15.1 sec 14.6 sec
@ 93 mph @ 96 mph
Braking, 70-0 mph 153 ft 145 ft
Roadholding, 300-ft-dia skidpad — 0.88 g
Top speed (drag limited) 144 mph 145 mph
seems more like a driver difference than automagically released power at xx,000 miles.
Old May 5, 2006 | 02:51 PM
zoom44's Avatar
here are some historic threads from about the time the rumour started. again there is no change built in to the ecu etc
https://www.rx8club.com/showthread.p...t=increase+ecu
didnt have time to look up the original rumour starter- i think there is one before the 1st thread i linked
Old May 5, 2006 | 03:21 PM
stickman's Avatar
The issue is torque more than horsepower and it is what it is.
Old May 5, 2006 | 03:58 PM
KYLiquid's Avatar
Oil Injection
Originally Posted by Glyphon
car and driver
also, i bet they had new (maby even different) tires, brakes, fluids, ect. By the time you hit 40k miles in this car, if you have done all the service, a lot has changed.
Old May 5, 2006 | 04:23 PM
dmp's Avatar
dmp
RX8 and a Truk....
This thread now has more HP than it did 1000 seconds ago. Seriously.
Old May 5, 2006 | 04:41 PM
Napboy's Avatar
Sho'Nuff
i thought the rumor was generated from something from the fd. i thought someone had posted a page from the owner's or service manual that said there was a swich at 15k miles. that was a long time ago though.
Glyphon's Avatar
脾臓が痛みました
no sure what all was change/replaced, they in the article they said that they switched to Yokohama Advan Neova AD07s at 30k miles when the potenzas wore out. so, any changes such as that could definately a pretty sizeable impact.
Old May 5, 2006 | 04:50 PM
dmp's Avatar
dmp
RX8 and a Truk....
So could shift points, etc...My old car went from 101mph traps to 105+mph traps based on me learning to 'get to 4th gear' quicker, and riding it out - rather than redlining every gear.
Old May 5, 2006 | 05:28 PM
r0tor's Avatar
thats what happens when the car breaks in...
Old May 5, 2006 | 09:27 PM
8_is_enuf's Avatar
Not sure how a different driver could make some of those changes, such as a faster top speed. Tires would not effect that either... Or the 5-60. (although that could be driver if one uses the clutch at 5mph.)
Old May 6, 2006 | 09:46 PM
The Prototype
The driver can make a big diffrence as well as well as tires. Tires have diffrent compounds that could cause more or less friction drag when contact is made with the road. Less friction drag, lighter weight tire will result in quicker off the line starts and over all faster acceleration to achieve a better top end. There has been several articles from compact sport magazine , motortrend that had tire test results that they used on stock vehicles. Within 5 diffrent tires on there stock vehicle(v6 honda accord) 3 out of the 5 tires when equipped proved to show faster times than the stock tires, and the other two tires they tested. I will try and find the article for you or you can look it up on the internet.
Old May 6, 2006 | 10:14 PM
StewC625's Avatar
Insanely Yellow
most cars gain a wee bit as they break in and age ...
Old May 7, 2006 | 04:07 PM
PhotoMunkey's Avatar
It's the extra carbon build-up on the rotor faces... Makes each rotor weigh more, giving better torque! <joking> :D
Old May 7, 2006 | 06:17 PM
NgoRX8's Avatar
so when can i get this extra power again?
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
