RX-Nut
08-13-2003, 11:44 PM
How do you folks warm up your RX-8. 0 minutes - JUST GO!, 5 minutes, 10 minutes?
I'd like to get a feel on what most rotary owners do..
View Full Version : Warm Up? RX-Nut 08-13-2003, 11:44 PM How do you folks warm up your RX-8. 0 minutes - JUST GO!, 5 minutes, 10 minutes? I'd like to get a feel on what most rotary owners do.. sferrett 08-13-2003, 11:58 PM I just let it idle until the idle smooths out and then off I go. Typically 20 to 30 seconds. I am wary to not give it too much stick until its warmed up (about 7 minutes) and keep the revs under 5k or something. This is in line with what's recommended in the manual also. I used to let my FD warm up for 5 minutes before going anywhere, but I figure if I just drive it gently for the first 5 minutes the you've got pretty much the same difference and you're 5 minutes ahead. Superfan 08-14-2003, 12:23 AM RX-8: idle for 1 minute and drive gently for 8-10min (to get the engine oil up to temp). FD RX-7: idle for 5 Minutes and drive gently until engine oil was up to temp (had an aftermarket oil temp gauge). |
