Should I cut the bump stop or not?
Old Apr 26, 2006 | 01:10 PM
MtlRX8's Avatar
Hey guys, I'm about to install my H&R springs onto my RX8 and I was wondering if I should cut the bump stop or not. Any experienced Tech's here that can help me out?
Nick
Old May 1, 2006 | 11:23 AM
iridearocket's Avatar
Not an experienced tech, but I have the H&R springs with Tokico shocks using the stock bump stops. I don't have any issues with bottoming out the car or noticing the bump stops at all. (Mind you, I don't try to get up to 60+mph and hit rail road tracks as hard as I can either.)
When I had the H&R's with the stock shocks there seemed to be far too much movement in the suspension travel and the bump stops may have been interfereing. But if they are interfereing, then they are doing their job to protect your shock.
The H&R's lower the car as much as I have seen any other RX-8, but I don't see any good reason to remove the bump stops for street use.
Old May 1, 2006 | 11:40 AM
QBallz's Avatar
Racingbeat springs don't have much of a drop but they recommend modifying the bumpstops. Thanks to Raz's members website I easily found a picture of me holding the modified stop for your viewing pleasure.
http://www.mazdanow.com/membersarea/peeps/QBallz.htm
Additionally if you put a small zip tie around the strut then go do some hard driving you can see how much play you have left in the strut. I noticed that under hard braking that I would have hit the stock bumpstop, but manage to miss it with the modified one.
Old May 5, 2006 | 06:23 AM
MadDashRX8's Avatar
Resu Deretsiger
Instructions don't specify? Tein s-techs said to cut it 1". Different amount of drop, though.
Old Feb 28, 2007 | 04:49 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
sorry i know nothing about suspension setups..
so what if you dont cut the bump stop when installing lowering springs?
Old Feb 28, 2007 | 05:49 AM
chrism's Avatar
Misfit Moderator TnC
if you dont cut them the car will hit them much faster in a bump....it will feel like you are slamming your car off the ground usually.....i cut mine about an inch too with the espelirs
Old Feb 28, 2007 | 06:45 AM
Mazda-Rati's Avatar
the WANKEL made me do it
I called H&R before installing mine and they told me NOT to cut the bumpstops.
Old Feb 28, 2007 | 07:01 AM
Mazda-Rati's Avatar
I now have the Espelirs and haven't cut the bumpstops with these springs.
i figure since they are .75 inch higher up front then the H&Rs and have a higher spring rate it just didn't make sense to cut them.
Old Feb 28, 2007 | 03:26 PM
apotocki's Avatar
Eibachs and Koni's here.....I cut my stops about 1 inch. No ill effects so far.
Old Feb 28, 2007 | 05:51 PM
NotAPreppie's Avatar
What am I doing here?
It's not just about lowering height. You also have to consider spring rate.
I'd leave the stops and cut them only if you run into issues with them.
Old May 28, 2016 | 11:35 AM
Jmanie9515's Avatar
What is the length of stock rear bump stops
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
D13
Oct 1, 2015 07:55 AM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Trekk
12
Sep 25, 2015 03:08 PM
