Shift Beep
Old Apr 22, 2006 | 08:03 PM
astrozoom's Avatar
Shift Beep
I purchased a 2004 RX-8 about two months ago. My buddy has an 05, and I know you hear a beep when you reach 8500, but in my 04, it does not beep. Does anyone know if the 04 is suppose to beep at 8500 or did mazda just start that in the 05 model? If it is suppose to beep, any suggestions on the fix?
Old Apr 22, 2006 | 08:15 PM
grapes's Avatar
It beeps.. Just turn down the radio and listen carefully. It just a tiny little chirp. Its there .
Old Apr 22, 2006 | 08:19 PM
Skythe's Avatar
Lascivious Post Whore
didn't we just have this discussion last week?
Old Apr 22, 2006 | 08:21 PM
REMillers's Avatar
yep have a 04 also, it only beeps once and it isn't very loud. You have a manual right? The auto's probably beep to since they have the paddles but really what would be the point in the auto...
Old Apr 22, 2006 | 08:27 PM
mdw1000's Avatar
I'll snap his neck.
The auto does beep if you have it in manual mode. At least my 05 does. Kind of hard to get it to beep in auto mode
Old Apr 22, 2006 | 08:29 PM
Raptor2k's Avatar
Club Marbles Member
I have an 04, I can hear the beep with music all the way up.
Old Apr 22, 2006 | 08:58 PM
Captain Amazing's Avatar
My beep is pretty loud
Old Apr 23, 2006 | 10:35 PM
Big_Mike_4488's Avatar
350Z Killer
I love the beep!
Old Apr 23, 2006 | 10:41 PM
SlayerRX8's Avatar
'03 Dodge Viper
Haha yeah, I had that happen once! I freaked out for a minute
Old Apr 23, 2006 | 11:15 PM
NgoRX8's Avatar
all rx8's have a beep at redline. I had a 2004 auto and that beeped. Now I have a 2005 manual and it still beeps. if yours does not beep you much not be listening. really, im serious. I actually have to expect it to hear it.
Old Apr 23, 2006 | 11:34 PM
Flynbri's Avatar
Rotary addict
My '04 beeps pretty loudly...never had a problem hearing it even with the radio up
Old Apr 23, 2006 | 11:37 PM
blakew15's Avatar
blakew15
makes you want to go test it!
I love the zooooooooo-ooooom BEEEEEP
Old Apr 24, 2006 | 03:27 AM
cjkim's Avatar
^noob
same... maybe you're not hitting redline? that's what i thought at first until i realized i had couple 100 rpms more to go. the engine sounds deceiving at 8000+ rpm
Old Apr 24, 2006 | 04:21 AM
terrypk1's Avatar
my 04 made in August beeps like crazy smokes. it beeps all the way from 8000K to 9K
Old Apr 24, 2006 | 01:01 PM
KYLiquid's Avatar
Oil Injection
i have driven an 04 and my 05 manual, both beep, its a solid Beeeeeeeeeeep, that comes on when you reach 8500 and doesnt stop until you lower the revs under 8500...its loud enough to hear with the radio below about 10.
I want to wire in a relay so it triggers a shift light, cause with the radio over about 10 or with the windows down at freeway speeds....you cant/can barley hear it
Old Apr 24, 2006 | 02:49 PM
Paul_in_DC's Avatar
Rotary Public
A shift light would be a good idea. When I'm on the track with a helmet on, windows open, and the wind going by at 100+ mph, there's no way I can hear that beep.
Old Apr 24, 2006 | 03:08 PM
cleoent's Avatar
n00b
Maybe your beep hasn't been enabled.
To enable it you have to go to your radio controls and hit:
Up down up down left right left right a, b, start.
Good luck.
Old Apr 24, 2006 | 03:14 PM
KYLiquid's Avatar
Oil Injection
true that, i have the same problem, im thinking of wiring in a relay to the speaker, so that it will trigger a small LED I want to mount somewhere near the gauge hood, above the tach.
Old Apr 24, 2006 | 03:15 PM
KYLiquid's Avatar
Oil Injection
Good luck.
ohh man, now hes gonna see the beep option in the radio menu and rev his car trying to figure it out......
Old Apr 24, 2006 | 10:06 PM
astrozoom's Avatar
Yep Heard It
Yep, I heard it today. I made it a point to make it complety quite in the car to make sure I would be able to hear it. It is actually fairly easy to hear. By the way, I am not playing Nintendo(Up Down Up Down Left Right On Off), I am driving a freakin RX-8!!! So much better then Nintendo!
Old Apr 26, 2006 | 06:46 AM
rotor_man's Avatar
I agree a shift light would be good, it is hard to hear with, wind engine and radio noise. The ideal spot would be just to the side of the tach with a small red led. ONe thing that might be a problem is the same beep is used for the lights on warning. The FD has a similar problem, they should have kept the old mechanical buzzer like in 70's rotaries. you can hear that easy even over a ported engine.
Old Apr 26, 2006 | 08:49 AM
NotAPreppie's Avatar
What am I doing here?
I got the beep once and I think that it was loud considering I heard it over the engine at WOT and through my helmet.
Old Apr 26, 2006 | 11:51 AM
seymore15074's Avatar
Registered Pimp
Good luck.
Wow, haven't heard that in a long time!
Anyway, all this talk about the beep makes me want to hear it again!
Old Apr 26, 2006 | 12:43 PM
Paul_in_DC's Avatar
Rotary Public
Be one with the beep. The beep is your friend.
