Painting Calipers
Old Apr 22, 2006 | 06:57 PM
FASTNMEAN8's Avatar
WHO's WANKEL?
Thumbs up Painting Calipers
hey guys i was wondering, how it was possible to paint my calipers? any DIY's to show me how? i did a search, but it didn't show me how... I want to paint them red...
Old Apr 22, 2006 | 07:04 PM
EZ99B5's Avatar
I've always had good luck with a product called Foliatec. It's a 2-part mixture that paints on with a brush with relative ease, and when it dries almost has more of a powder-coated look/feel than paint. You can usually find it online for <$50.
Old Apr 22, 2006 | 07:10 PM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-painting-brake-calipers-22567/
Old Apr 22, 2006 | 08:05 PM
NgoRX8's Avatar
^ that's weird... searching "DIY brake caliper" or "DIY caliper paint" doesn't find this thread...
our search feature is screwing up.
Old Apr 22, 2006 | 08:11 PM
tiggerlee's Avatar
May Cause Anal Leakage
If you search in DIY for "calipers" it's the third thread shown.
https://www.rx8club.com/search.php?searchid=1400149
The search function can be temperamental sometimes.
Old Apr 22, 2006 | 09:33 PM
expo1's Avatar
He's as bad as Can
True, plus with this board being around almost four years doing a simple search on the whole board will return too many non-related posts. If you have a good idea which sub-forum the post might be in, do a search within that specifc forum.
Old Apr 23, 2006 | 12:04 AM
tekk's 8's Avatar
JRZBOY 8
Hey, How much would you charge me if I asked you to paint my calipers for me?
Old Apr 23, 2006 | 03:17 AM
Beodude123's Avatar
It is a pretty easy process. I did the brakes on my RS2000 not too long ago.
I used regular spray paint with an acrylic coat, but you probably should use specific paint for it. So far it hasn't come off, but I'm sure it's a matter of time.
Anyways, all you have to do is unbolt the caliper from the frame, prep it with a wire brush, get all the dirt and stuff off. Then get some primer and put a couple of coats on. After that dries (primer seems to dry pretty quickly), put the red paint on. I did three or four coats. That way it has a good amount on there. After that, do the acrylic. I did about 5 coats of that, since it is the protection. The brakes look pretty good after that.
Just make sure you cover any of the friction surfaces (pads and rotors) because they will stink otherwise.
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
TheRedRotor
Sep 22, 2015 05:30 AM
