oil system description?
Old Apr 18, 2006 | 02:42 AM
daisuke's Avatar
rotorized!!!
can someone describe to me in some detail the oil system in a rotary engine (as in what turns in what, what gets lubed and how)? I've tried looking on the net and haven't found anything
Old Apr 18, 2006 | 04:01 AM
start here.
https://www.rx8club.com/rx-8-faq-9/
Old Apr 18, 2006 | 05:04 AM
yiksing's Avatar
the giant tastetickles
Every part gets lubed and rotor turn in housing
Old Apr 18, 2006 | 06:15 AM
StealthTL's Avatar
Metatron
Question Oil try.....
Oil pump sends it thru the passenger side oil cooler, then over to the drivers side cooler, up top to the filter where the pressure gets measured, then into the excentric shaft bearings and back to the pan.
The sides of the rotors get some, the inside of each rotor gets its own flow, and a tiny bit is pumped by a computer regulated pump into the actual rotor housing to lubricate the seal between housing and rotor. This flow is not recovered, it burns with the fuel.
System holds about 8 litres, but only about 4 come out with each oil change, the rest is in the cooler/filter system.
S
Old Apr 18, 2006 | 03:17 PM
daisuke's Avatar
rotorized!!!
ok, that's what I wanted to know, thanks stealth.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
Cookingislife1226
Sep 5, 2015 03:38 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
