Flashing your ECU..
Old Apr 17, 2006 | 10:05 AM
SoloMazda8's Avatar
Leisy
Flashing your ECU..
Was wondering what is a Flash? Whats does it do for your car? Ive had my car to the dealer 3 or 4 times, will they automatically flash it for me or do I have to ask? Tried searching first, so if this is a repost sorry.
Old Apr 17, 2006 | 10:12 AM
tuj's Avatar
tuj
A flash is a set of code and parameters that live in the ECU. These parameters determine how the engine and other systems of the car are managed by the ECU. The dealer will automatically update the ECU when they hook the car up to the WDS and it determines that you need a new flash. Mazda periodically releases flashes to fix problems and improve the car.
There is TONS of information on this subject on this forum, so you probably didn't search very hard.
Old Apr 17, 2006 | 11:00 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
To paraphase, the "flash" is the program for the engine control unit (or PCM--powertrain control module). Mazda periodically tweaks it, especially in terms of the fuel/air ratio at different portions of the rpm spectrum, but a new flash could change any of the engine control parameters.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
ErwinN
Sep 23, 2015 09:29 PM
Forevermore
Sep 20, 2015 01:04 PM
