Checking CEL
Old Apr 8, 2006 | 04:57 PM
Waz's Avatar
Waz
Checking CEL
Is there any way you can check what a CEL means without an OBD computer? I remember in my Celica there was a wire trick and you could see how many times the CEL blinked and then work out the code from there. I have a CEL which comes on then goes off sometimes. Have a feeling it might be my midpipe but just want to be sure.
Thanks,
Waz
Old Apr 8, 2006 | 06:30 PM
Go48's Avatar
Not that I have heard of but there could be something like that because the 2nd gen RX-7 had that capability. Did you remove the O2 sensor when you installed the midpipe? Could be that unless you installed some sort of fooler. Could be something as simple as a loose or non-sealing gas cap. Are you sure this is the CEL and not something like a TPMS light? When does it light? If it blinks momentarily when you run up the revs it may be a random misfire. You will likely have to read the code(s) with an OBDII, CANbus-compatible scanner.
RevMeHarder
Jun 1, 2026 02:30 PM
LB2739
Jul 9, 2019 02:25 AM
WranglerFan
Nov 5, 2017 09:35 AM
DVerdeyen
Sep 13, 2015 11:19 AM
Irvinb16
Sep 11, 2015 10:27 PM
