suspension wear with milage?
Old Apr 6, 2006 | 12:55 PM
al2134's Avatar
Other than the shocks wearing out, has anyone upgraded suspension wear items (shock mounts, bushings, etc) as the miles add up (eg, after about 30-40K miles)?
I know that on the BMW 3-series, for example, that there wear items that sometimes need replacing (ball joints, trailing arm bushings), but I am not sure on the RX-8.
Old Apr 6, 2006 | 01:03 PM
Joe_914's Avatar
Well I would imagine there will be replacement items. Shocks probably #1 on the list. Rubber bushings next.
If the Miata's are any indication you will have the car for a long time before things need replacement.
Old Apr 6, 2006 | 01:05 PM
expo1's Avatar
He's as bad as Can
60,000 miles and the only thing I had to do was put grease fitting on my sway bar bushings.
https://www.rx8club.com/series-i-trouble-shooting-95/something-owners-aftermarket-swaybars-might-want-lookout-65304/
Old Apr 6, 2006 | 01:12 PM
daisuke's Avatar
rotorized!!!
Parts on modern cars last a long time, my saturn has 243,000 miles on it and the suspension parts still work fine.
I had a thunderbird that had worn out suspension joints, but then again that's a Ford from their crappiest days, that car's engine was also prone to head gasket failures and the plastic trim tended to crack in the sun (huge cracks)
I wouldn't worry about it and I second expo's suggestion, put zerk fittings on the joints to grease them every once in a while.
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
