Nice rear end!!!!!
Old Aug 11, 2003 | 08:10 PM
Steve T's Avatar
Accumulator
Nice rear end!!!!!
Had the RX-8 up on the lift this afternoon just to take a look around under the car.
I noticed the rear diff is very cool looking. Has a lot of cooling fins.
Old Aug 11, 2003 | 08:53 PM
OmegaBob's Avatar
Seeing pics like that is seriously making me consider dealer undercoating b/c I thought that the cars had some form of it from Mazda when built.
btw - very nice pic!
Old Aug 11, 2003 | 09:34 PM
neit_jnf's Avatar
What's the diameter of the stock exhaust? It looks huge! (3 inches? )
Old Aug 11, 2003 | 09:35 PM
Racer X-8's Avatar
Coming thru in waves...
Isn't that "bare metal" the gas tank?
Old Aug 11, 2003 | 10:42 PM
OmegaBob's Avatar
Ummm. I dunno.
Old Aug 11, 2003 | 10:52 PM
Boozehound's Avatar
Get Hooked
It really matters what kind of metal it is, not just if it's coated. Would you worry if the undercarriage was all stainless? Or aluminum? How many Delorians are rusting through their body panels?
Old Aug 12, 2003 | 02:11 AM
Doctorr's Avatar
Ricer is Nicer.....
Cool Coated?....
If you can make out the detail in my crappy photo, the metal 'X' is the gas tank's shiney heat shield...
Supported by painted metal bracket 'Y'....
And the gas tank would be the Black plastic piece 'Z' on the right...
And Exhaust 'A' is 60mm, about 2.3"
doc
Old Aug 12, 2003 | 08:23 AM
Steve T's Avatar
Accumulator
OmegaBob, I did notice some form of undercoating. I think you may be seeing the heat shield around the diff.
neit_jnf, The exhaust is fairly large (did not measure it) and it looks like it all bolts on. Should make any aftermarket swap very simple, ramps and hand tools only. I can e-mail you several higher res photos of the entire exhaust system if you want them.
Doctorr, thanks for clearing up the gas tank issue and for the exhaust info.
I will try to edit a few (the original pics are approx. 1.2 to 1.5 meg each) of the pics and post them in the photo section.
One thing I found interesting is the brace that connects to the trans and runs to the diff. I guess this is part of the backbone of the car, looked cool.
Moderator - Sorry for posting this in the General forum, should have gone in the photo section...
Old Aug 12, 2003 | 08:42 AM
dcfc3s's Avatar
RX-7 Guru
One thing I'm VERY impressed by is that Mazda used mandrel-bent exhaust piping - all RX-7's came stock with some atrocious crush-bent piping.
Steve T, welcome to the world of Japanese cars . I don't know why American car companies don't have bolt-on exhaust - all Japanese cars use simple bolt-on exhaust sections. You never have to do any cutting or welding. The RX-7 was the same way - manifold that had a pre-cat bolted to it, that had a main cat bolted to it, that had a cat-back bolted to it.
Dale
New Yorker
40
Mar 22, 2022 06:01 AM
WingleBeast
22
May 23, 2016 09:22 PM
ColeParkerrr
Sep 15, 2015 07:30 PM
Bill_Monteith
Aug 18, 2015 07:11 AM
