Does the rx8 spin out easily?
Old Apr 4, 2006 | 12:30 AM
SSJ 909's Avatar
I was just wondering after the bs that happend with my Camaro a few years back, how easy is it or should I say how hard is it for the rx8 to spin out?
Thankz
Ash
Old Apr 4, 2006 | 12:36 AM
Soundave's Avatar
Decepticon
Hasn't happened to me yet and I'm inclined to say it won't happen to me anytime soon (unless I go FI ). I don't think we have enough torque to cause the wheels to break loose uncontrollably.
Old Apr 4, 2006 | 12:37 AM
projektIRL's Avatar
i take really tight turns in even in the rain and i have yet to spin out.. i do it all the time in my truck .. but not my RX-8 and my suspension is stock
Old Apr 4, 2006 | 12:46 AM
terrypk1's Avatar
as far as i think, rx8s are pretty tail happy cars. when you go in a 90 degree corner in first gear, if you give it a little more gas, your car will spin out. (the DSC kicks in) i don't know if this is true for all rear wheel drive.
and i talked to some other guy who drives a MR2 Mark2. after he drove my car, he said that this car is more tail happy than his mr2.
Old Apr 4, 2006 | 02:10 AM
Rhawb's Avatar
Has the whole shit.
It's no more tail happy than any other RWD car and even when you do kick it around, it's quite controllable. If I'm not mistaken, MR2s are FWD and unless the mid-mounted engine makes a huge difference from FF cars, it would make them very much prone to understeer, not oversteer.
Old Apr 4, 2006 | 02:18 AM
Michael's Avatar
MR2!!!!
M stands for Mid-Engined
R stands for REAR WHEEL DRIVE
2 for 2 seater. (This is the edit)
MR2 is a very comparable car, tis lighter but it's got the same balance that our 8's do.
Old Apr 4, 2006 | 03:26 AM
DOMINION's Avatar
I don't buy Kool-Aid
Thankz
Ash
Depending on how you drive you can will get squirrelly. I know when it rains you have to drive with caution and after I wash my car I will help the wheels dry up good and my friend has 20's he got squirrelly comeing off the free way.
Old Apr 4, 2006 | 07:08 AM
ndtechie09's Avatar
I'm Burnin for You
im nervous on the stock tires, i ordered new tires yesterday so i shouldnt have to be nervous but my potenza's are worn to hell
Old Apr 4, 2006 | 07:21 AM
Gambit's Avatar
Screw gas mileage
Thankz
Ash
Keep the DSC on and you won't have a problem
I can't tell you how many "I took off the DSC and crashed my car" threads i've seen
Old Apr 4, 2006 | 07:52 AM
Animagix's Avatar
rx8 is one of the better handlers at the limit. fishtails can be tamed.
Old Apr 4, 2006 | 08:00 AM
Brice-RX8's Avatar
As long as you have DSC on the car controls itself for the most part. I see the only reason to disable DSC is if you are confident enough to be able to control the car on a track or backroad without computer help. I know that on my car the only way to get the tail out now with 245/40 tires is 1st gear and a 90 degree turn.
Old Apr 4, 2006 | 08:13 AM
Coop '04's Avatar
DELIVERED 07-17-2004
I had 3 different Z28 Camaros and they all were very unrefined and could get out from under you quickly. I know what you mean and it could be spooky at times. The 8 is a whole different machine, you will not have any issues like you did with the Camaro. And lastly thank you for spelling Camaro correctly.
Rich Rx-8's Avatar
I agree with the DCS staying on if you're worried. I took DSC off one day and did a very nice fish tail and found it very easy to pull 180 degree u turns. Keep DSC on.
Old Apr 4, 2006 | 08:21 AM
RotaryNoob's Avatar
Hi
I did a 180 once by accident. Gave it a little too much gas into a badly banked onramp with bald tires. I ended up in the dirt (no damage) but it reminded me that it is possible...
Old Apr 4, 2006 | 09:26 AM
snizzle's Avatar
Shakezula, the Mic Rula
I did a complete 360 once with DSC off on a sharp turn in 1st gear. Almost ended up in a ditch. Needless to say, I don't turn it off anymore.
Old Apr 4, 2006 | 09:27 AM
Groo's Avatar
Originally Posted by Michael
MR2!!!!
It's actually Midship Runabout, but it's definitely true it's a RWD vehicle. :-)
And to answer the original poster's question, the RX-8 can fishtail but I don't see it as a reason to avoid the car. It's just a matter of learning how to handle the vehicle.
Old Apr 4, 2006 | 09:31 AM
ZoomZoomH's Avatar
Mulligan User
if you want to avoid spinout alltogether, get a FWD family sedan....
Old Apr 4, 2006 | 09:35 AM
DARKMAZ8's Avatar
"Call me Darkman"
No DSC here. ONly spun out once doing an S turn too damn fast. Otherwise I've taken turns fairly fast and just counter steer when tail loses some grip. It's a blast. I'd hate to have dsc on all the time. Takes the fun out of owning a rwd car.
Old Apr 4, 2006 | 09:59 AM
Brice-RX8's Avatar
DSC will actually let you get a little friskey with the rear end before it applies a brake. It just helps you out if you push the envelope too far.
Old Apr 4, 2006 | 10:23 AM
allmotorRX8's Avatar
銀い 雪
you are mistaken
Old Apr 4, 2006 | 10:29 AM
wallyb's Avatar
No DSC and liking it
No DSC here. I haven't spun out yet but it's easy to correct once the rear end comes loose. Its actually one of the things that makes the car so fun to drive. Also scares the crap out of my wife which can be good or bad!
Old Apr 4, 2006 | 10:30 AM
Deslock's Avatar
WWFSMD?
All cars, especially RWD, can spin out. But the RX8 is very forgiving and less prone to snap oversteer than most other RWD cars I've driven. And if the back-end does slide, you usually have a better chance at recovering with RWD than with FWD (depending on the situation and your skill).
One way to learn how your car behaves is to experiment with sliding around in a big empty parking lot where you have lots of room and there are no people around (ie don't be an idiot). Try various combinations of changing direction while giving it different amounts of throttle. If you have DSC, disable it for at least half of your trials.
Just watch out for curbs, light poles, etc and most importantly be careful not to hurt yourself or anyone else. And don't push your luck... keep your speed safe and reasonable and don't call attention to yourself (you're likely to get in trouble if a cop catches you). Also, doing it on a slick surface (rain/sand/snow) will cause a lot less tire wear.
Old Apr 4, 2006 | 10:34 AM
SSJ 909's Avatar
lol how else have u seen camaro spelled?
Yea I had a 98 6 cyl. I was cruising on the highway doing around 60 ish in the left lane. The road starts to turn a bit, nothing to crazy, and all of a sudden I start drifting into the middle lane Im like wtf?
I try to catch it and bam 360 into the guard rail.
Sucked sooo bad!
I figured since the weight dist in the rx8 was near 50 50 that spinnign out wouldnt be such a problem. I just dont want to have to worry about things like that.
Thankz for your input boyz n girlz
Old Apr 4, 2006 | 10:57 AM
ndtechie09's Avatar
I'm Burnin for You
o and as rickeo and i found out the other day, don't put tire shine on and then drive it hard
Old Apr 4, 2006 | 10:59 AM
DARKMAZ8's Avatar
"Call me Darkman"
The Camero handles like shiat. It's fast(v8) for the highway but it handles nothing like the 8.
