will 275/35/19 rub?
Old Apr 3, 2006 | 02:58 PM
xrider01's Avatar
will 275/35/19 rub?
will 275/35/19 rub? i'm currently running 275/30/19 set on my rear wheels, but for my next set, i'm wondering if i could run a slightly larger set of wheels on my rear wheels and still not rub or scuff my wheel wells or fenders
Old Apr 3, 2006 | 03:08 PM
BigOLundh's Avatar
#1 Legend
well... best way to check is look at your current space. Do you have room for and additional 13.75mm?
You can probably answer this question better than the rest of us. I am running 275/30/19 at the moment, and on my car going to 35 won't be a problem. The thing is... we probably have a different suspension set up.
-hS
Old Apr 3, 2006 | 03:20 PM
xrider01's Avatar
only suspension upgrade i have on my 8 is the eibach springs. 30mm drop. i can barely stick two fingers in between the gap of my wheel and the fender.
Old Apr 3, 2006 | 08:09 PM
hoosteen's Avatar
"No 8 Left Behind"
what's the offset.
Offset is one of the main factors.
Old Apr 3, 2006 | 09:12 PM
BigOLundh's Avatar
#1 Legend
well, are your two fingers greather than or less than 13mm? It sounds to me like you won't have the room to go 275/35/19
-hS
Old Apr 4, 2006 | 04:52 AM
RX4life's Avatar
its not finger gap but more to do with offset as mentioned previously..remember camber my wheels stick out of the fender.. but i dont rub because of that magical camber!!!!
Old Apr 4, 2006 | 12:27 PM
xrider01's Avatar
i don't have a ruler to measure my two fingers to see if they are greater or less than 13mm
and......what is offset? i mean, i know it has something to do with the size of the wheel, but not really sure what it is.
Old Apr 4, 2006 | 12:44 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
The 35 series is going to use up another 1/2" of your space.
Tire Size Sidewall Diameter Circumference Rev/Mile Difference
225/45-18 4.0 in. 25.97 in. 81.59 in. 777 0.0% stock
275/30-19 3.2 in. 25.50 in. 80.10 in. 791 -1.8%
275/35-19 3.8 in. 26.58 in. 83.50 in. 759 2.3%
Old Apr 4, 2006 | 01:00 PM
xrider01's Avatar
that's why i want the 35 size tires
Old Apr 5, 2006 | 05:22 AM
RX4life's Avatar
offset is how far your wheels stick out in relation to the width of the wheel... the lower the offset of a rim the further it sticks out..
Old Apr 6, 2006 | 02:11 AM
xrider01's Avatar
i forget the offset of my rims. is there a place that will tell me what the offset is, or is there a way i can measure it myself? My rims are the Axis Hiros, and my current configuration is as stated below (if it helps).
Front: 245/35/19
Rear: 275/35/19
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
WingleBeast
22
May 23, 2016 09:22 PM
czr
Sep 13, 2015 11:37 AM
GrAfiX
Aug 24, 2015 08:08 AM
