MS Front Bumper grill...
Old Mar 27, 2006 | 05:15 PM
Waz's Avatar
Waz
Hi,
I have an authentic MS bumper on the car and noticed that thru one of the mesh bits I can see an oil cooler but the other grill has some plastic backing hiding the oil cooler!? Is this normal?
Thanks,
Waz
Old Mar 27, 2006 | 05:18 PM
BigOLundh's Avatar
#1 Legend
looks like whoever you bought it from had an auto, and just 1 oil cooler.
The MS Front bumper kit comes with that backing, but you are not supposed to install it unless you have 1 oil cooler. If you have 2 oil coolers... i recommend taking that off immediately.
-hS
Old Mar 28, 2006 | 02:29 PM
Waz's Avatar
Waz
I have a manual. Any instruction on taking the thing off? Done 11k with it so far. Previous owner never took it off. Hope it isn't bad...
Old Mar 28, 2006 | 02:43 PM
Dro's Avatar
Dro
Uhhh you were only getting 1/2 the oil cooling ...
Old Mar 28, 2006 | 03:00 PM
Waz's Avatar
Waz
the temp scale has always been level, mind you that only shows the coolant temp.. I have a UK 230, is that meant to have 1 cooler or two?
Old Mar 28, 2006 | 03:36 PM
TownDrunk's Avatar
I am a meat popcicle
You'll have to remove the bumper cover to take the plate off. The plate just screws on, so it's pretty easy to remove (again, once the bumper cover is off).
Old Mar 28, 2006 | 03:38 PM
Waz's Avatar
Waz
Hi, thanks for the advice mate. Bumper cover or do you mean the bumper? If it is the bumper anyone have a guide showings how many bolts need to be taken off? Bit concerned about only half the oil been cooled, not sure if I should be worried or not as the Aussies only have one oil cooler on their Hi-Powers and they r ok....
Old Mar 28, 2006 | 04:05 PM
TownDrunk's Avatar
Yep, by bumper cover I mean basically the bumper (actually the exterior piece that fits over the bumper). I think there's a DIY somewhere here that explains how to take the thing off. Search for something like: bumper cover removal
I'm guessing Aussie MT '8s also have two oil coolers (can't imagine why they wouldn't), so you'll certainly want to make sure both are getting all the fresh air they can.
EDIT: Here's a link to a thread that shows how. Good luck!!
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-removing-bumpers-10941/
Old Mar 29, 2006 | 02:45 PM
Waz's Avatar
Waz
Thanks for the link! Did it today and there was indeed two oil coolers!
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
paporx8
Nov 5, 2015 07:20 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
