18x7.5
Old Mar 22, 2006 | 09:32 PM
W1CK3Dninja's Avatar
18x7.5
i really like the enkei rs-7 but the largest size they make is 18x7.5, i just found out that our stock wheel is 18x8. do you think the 7.5 width is gonna effect the performance. i just want atleast stock performance. the tire package i would get the rims with come with 225/40/r18. let me know.
Old Mar 22, 2006 | 09:51 PM
dont know what the rs-7 is, but i am running the rp02 18x7.5 45mm. you need to run the stock size 225/45 18.....
weight 18.1 lbs per wheel
Old Mar 22, 2006 | 10:13 PM
BigOLundh's Avatar
#1 Legend
I personally would not put hte rs-7s on my car, but if thats what you want...
18X7.5 should be alright. You're probably not going to be able to go much wider than a 225, which is what your stock tire is anyway.
What exactly about the rs7 did you like? If it was the 7 spoke design or performance from a light wheel.. i'm sure you can find a much better alternative.
-hS
Old Mar 22, 2006 | 10:36 PM
i like the looks. bronze with the polished lip looks sweet on a black 8.
http://www.wheelsnext.com/product.phtml?p=1603
if you have any alternatives give me some ideas. although i want to stay under $1400 and that's including tires. also the wheel must be gold or bronze.
Old Mar 22, 2006 | 10:41 PM
kinda weird looking but its your car..
Old Mar 22, 2006 | 10:44 PM
i think i win the weird looking for our car, but it is light and not expensive.....
Old Mar 22, 2006 | 10:50 PM
BigOLundh's Avatar
#1 Legend
What color is your 8?
Here are 4 I would recommend (pics attached)
5 Zigen GN Pro
Gram Lights Pro
Volk CE 28n
Volk TE 37
The 5zigens are going to be your most affordable rim out of the 4. IMO it also looks fantastic. I almost went with this rim myself. You should be able to easily find a set of 4 under $1400, and they also come in 18X8.5 as well as 18X9.5 - which will allow you to stick more rubber on there.
I am pretty sure all 4 of these rims are also going to be lighter than the Enekei RS7. Enkei makes a great set of wheels in their racing line, but the RS7 is from a different line.
-hS
Attached Thumbnails 18x7.5-pracer_gn_mattbrz2_600.jpg   18x7.5-gl_57pro_g_ci3_l.jpeg   18x7.5-ce28ngd.jpg   18x7.5-te37br.jpg
Old Mar 22, 2006 | 10:54 PM
5 Zigen GN Pro
Gram Lights Pro
Volk CE 28n
Volk TE 37
-hS
wow,
big, big money....
my not so pretty wheels were.
`400bucks shipped. with lugnuts and hupcentric rings.
18.1 Lbs per rim.
Old Mar 22, 2006 | 11:40 PM
if you're running 225 or 235 tires you won't be able to tell the width difference and they'll be less likely to get scuffed against the curbs for that tire width, sounds like an economical alternative and if you get some good tires it can probably handle better than OE despite the narrower width
Old Mar 23, 2006 | 09:13 AM
GeorgeH's Avatar
I noticed a difference when going from an 8 to an 8.5 on 245s. Tires take a set better and the slip angles don't grow as large. I can't tell you if the car is faster but I can tell you it subjectively feels better - more linear on the limit.
But, with the lower profile of a 225/40 it will probably still handle just fine on a 7.5. Personally, I'd reccomend against as I think your handling will suffer subjectively if you ever go wider than a 225, but it does sound like an economical (and light) alternative.
Old Mar 23, 2006 | 05:49 PM
i'm not gonna go over 225. i just want it to handle as good as stock atleast. also getting tein springs.
Old Mar 23, 2006 | 06:56 PM
grapes's Avatar
I think that's a good choice both on the wheels and tire size 225/40/18's are not too wide for 71/2 inch rims Go for it. Good Luck.
Old Mar 23, 2006 | 07:19 PM
thanks i'll post pix when i get it installed.
200.mph
Dec 10, 2018 03:49 PM
Protege_Guy
Sep 1, 2009 12:53 PM
tsx
May 31, 2009 12:00 AM
igotta3
Aug 15, 2008 03:25 PM
hamsta
Aug 10, 2006 06:25 AM
