cezacho
03-22-2006, 08:13 AM
Hey guys
I was wondering if any of you could help me with this problem. The cluch makes a little noise when in neutral. It's barely noticeble. When I press the pedal it goes away. Is it normal for cluch to make noise like that?
yiksing
03-22-2006, 08:29 AM
Search, search, search
This has been covered way too many times...
This has been discussed many, many times before on the forum. It is not the clutch, it's the transmission main shaft rolling on it's bearings. Normal for this car. When you press on the clutch pedal, the main shaft is disengaged from the engine and no longer turns.
BTW, welcome to the forum! The search function and reading, reading and more reading is your best friend here. Lots of very valuable information on this forum on the car. Check out the DIY section particularly.
cezacho
03-22-2006, 08:37 AM
thanks guys...I did the search for "cluch" and none of that came up...what fraze should i type in?...oh and another thing is that i've never heard it before...i have 35000 miles on it and i started hearing it recently...and should i cancel my appoitment with the dealer then?
Yeah, cancel it unless you want verification of what we tell you.
BTW, it's cluTch. Maybe that's why your search didn't find anything. Ya think? :)
cezacho
03-22-2006, 09:03 AM
ah you were right it's been covered...thanks.
