Low Compression Rotors
Old Mar 21, 2006 | 03:12 PM
lourx8's Avatar
Early RX8 Adopter
Searched but couldn't find anything. Do they make them for the Renesis? If so, where to get them. Rebuilding motor
Thanks guys
Old Mar 21, 2006 | 03:31 PM
Red Devil's Avatar
I don't believe anyone offers these for the Renesis. Mazda is the only one that makes rotors. Everyone else only alters their original part.
What happened to your engine?
Old Mar 21, 2006 | 03:36 PM
lourx8's Avatar
Early RX8 Adopter
Im gonna really find out when the motor is taken apart. Right know the car sounds really weak and it runs like its on one rotor.
Old Mar 21, 2006 | 03:39 PM
Jabberwock's Avatar
Racing Beat has Lightweight rotors for the renesis.
http://www.hopupracing.com/rabeliroasma.html
Old Mar 21, 2006 | 03:43 PM
Red Devil's Avatar
That's a lot for a street driven vehicle. And they do not lower compression as Lou asked.
Old Mar 21, 2006 | 03:48 PM
lourx8's Avatar
Early RX8 Adopter
Yeah, I'm actually looking for lower compression. Alex Lopez is the guy that is going to do the rebuild. He said he was gonna do 3mm seals and polish, etc. However, he mentioned low compression rotors, and I figured I'd find out if they make them. The guys is a boricua (Puerto Rican) and knows rotaries. I visited the shop and there were RXs everywhere. I'm just wondering why he would mention low compression rotors for the Renesis.
Old Mar 21, 2006 | 03:55 PM
Red Devil's Avatar
What kind of power are you looking to make?
The Renesis apex seals are supposed to be much stronger than the FD's. FD apex seals were good for 500hp and more...
Old Mar 21, 2006 | 04:04 PM
lourx8's Avatar
Early RX8 Adopter
My goal is to make sure the motor is strong enough so I dont have to through this again. I have the Greddy turbo, and plan on staying with it for now. Initially I'm looking to make 300 whp. Later later upgrade turbo. I just have to wait until my wife gets over this little bump on the road :
Old Mar 21, 2006 | 04:14 PM
epitrochoid's Avatar
Riot Controller
Figure out why your engine blew, as it's likely that the greddy kit will only hurt you with lower compression rotors. More boost isn't the answer, as it will taper off in the same way a low boost setup will, only start sooner.
The 300hp restriction isn't likely the fault of the turbo, but a fault of the exhaust ports which are the limiting factor in terms of airflow. With 10:1 and 13 psi you can get a decently safe 300whp, but you're better off sacrificing some AFR and timing to end up with something between 285 and 300 (i've seen what it takes for 300whp, and it's pretty lean and has a pretty high injector duty cycle, neither of which are good if you drive under conditions that already caused a blown motor). Until someone figures out how to increase the volume of the exhaust ports, we're stuck around 300whp, since the Renesis just can't flow well with boost above 7,000rpm. This may involve having to use various parts from previous rotaries, including lower compression rotors.
Old Mar 21, 2006 | 04:19 PM
lourx8's Avatar
Early RX8 Adopter
Thanks for the input epitrochoid, I'll find out exactly what happened as soon as my baby goes in for surgery. I know that I will be getting new injectors and I ordered a fuel pump as well. I have the interceptor already so I think I will be alright after the rebuild. I dynoed at 278 - 292 with the emanage. I would definitely be happy with that, so 300 whp isnt a must.
Old Mar 21, 2006 | 04:40 PM
rkostolni's Avatar
It sounds like you are just guessing that your motor is blown though. Have you actually done a compression check? If one of your leading coils burns out it will cause the car to be way down on power and feel like its running on only 1 rotor.
Old Mar 21, 2006 | 04:56 PM
Nemesis8's Avatar
Bigus Rotus
Maybe he read the interview with AMEMIYA-SAN by RXTuner. See page 15 of 18 in this PDF document discuss the 13B-REW rotors.
http://www.rxtuner.com/farticles/JGTC.pdf
Old Mar 21, 2006 | 05:03 PM
lourx8's Avatar
Early RX8 Adopter
True, I just asked the rotary guy what he thought about the way my motor sounded.
Old Mar 21, 2006 | 05:08 PM
lourx8's Avatar
Early RX8 Adopter
Hhhmmmm interesting, thanks for the link Nemesis, I dont have that issue.
Old Mar 21, 2006 | 05:14 PM
rkostolni's Avatar
I wouldn't get too excited about getting a new engine then. The coils on this car are known to burn out. There's also many other things it could be, fouled plugs for example.
Old Mar 21, 2006 | 06:09 PM
lourx8's Avatar
Early RX8 Adopter
LOL, you're right, in a twisted way I am getting excited, I mean who could get excited about spending $$$ like this right? I know that we had changed the plugs the night before so it may not be the plugs. I'll have them and the colis checked.
Old Mar 23, 2006 | 06:58 PM
Mazmart's Avatar
That's probably Carlos Lopez.
Old Mar 23, 2006 | 07:54 PM
lourx8's Avatar
Early RX8 Adopter
Yeah Carlos Lopez is well known. I've been getting that alot, but no it's actually Alex Lopez. If all goes as planned, my motor will be in his hands tomorrow.
Old Mar 23, 2006 | 07:58 PM
anthonysfetcopoulos's Avatar
hey ive blown my engine on the rx8. i dont even have FI haha i got a microtec but i thrash the **** out of it so thats why its wrecked..
do you have an exhaust on your car? the car sound way way quieter when the compression goes and you have like 50%less power. Does it stutter like **** when u go over 5 grand? thats what mine was doing so i took it in and new im getting new engine all expenses paid by mazda ; ) ha ha ha
Old Mar 24, 2006 | 10:14 AM
lourx8's Avatar
Early RX8 Adopter
Yeah bro, thats exactly what it sounds like. The engine will be out today, If they take it apart today, then I will be able to update as to the condition of it. I have the interceptor, basically an LT10, did you get your microtech from mazport?
Old Mar 25, 2006 | 02:05 PM
Raptor's Avatar
Well it kinda sucks, you blow your engine because you messed up with the microtech and now you have Mazda pick up the tab, that's cheating and you seems proud of it?
I hope the dealer you brought it in read your post and denies your replacement.
Old Mar 29, 2006 | 06:22 PM
ttt's Avatar
ttt
hater
Old Mar 29, 2006 | 06:31 PM
and maybe God will read this post, crash a 747 fully loaded with fuel into your house, and then deny you admittance into heaven for being so hateful
Old Mar 29, 2006 | 06:43 PM
BigOLundh's Avatar
#1 Legend
and maybe then Superman will read this post, and do... umm... something really kinda bad sorta... ok i dont know where im going with this,
Old Mar 29, 2006 | 10:07 PM
LOL, I just ordered some kryptonite just in case
