Flashing TPMS light
Old Mar 21, 2006 | 02:54 AM
bedrock83's Avatar
!!Speed Racer!! VrOoM
Flashing TPMS light
Can anyone tell me what a flashing TPMS means? I dont think the pressure is low because I checked it, and I just got new tires about a week ago, and it was doing it before and after. It kinda bothers me, I'm thinking one of the sensors went bad. Any advice would help. Thanks!
Old Mar 21, 2006 | 03:04 AM
must read owners manual!!!!!!
Old Mar 21, 2006 | 06:05 AM
Go48's Avatar
Check tires when cold and if that doesn't clear the light, have a dealer check it out.
If the tire installer damaged a TPMS sensor, they should replace it at their cost, but unless the tire work was done by the dealer, don't hold your breath. Those sensors cost ~$100 each, so hope that it is out-of-range tire pressures causing the problem.
EDIT: "Therefore, the warning light illuminates when tire pressure is too low or too high in one or more tires, and flashes when there is a system malfunction." (The Manual)
Old Mar 21, 2006 | 06:31 AM
gonnahanvan8's Avatar
Check you tire pressure. The TPMS sometimes leak if they are not installed corectly, they are finicky about the amount of torque applied to them. Get some soapy water in a spray bottle and check for a slow leak around the valve stem where it contacts the rim.
Old Mar 22, 2006 | 07:04 AM
VOODOO8's Avatar
Hermitage Holdout
Second the advice from gonnahanvan8, the sensors are somewhat fragile. I damaged one taking an aftermarket cap off. Although I used thread ease when I first put the caps on, one of them bound up tight enough that I could not remove it by hand. Grabbed a set of pliers to grip it better and broke the epoxy seal between the valve stem and the body when I applied torque which resulted in a slow leak. They are not cheap to replace.
Old Apr 6, 2006 | 10:30 AM
semperfi8's Avatar
My car had the same problem. It would flash yellow after driving for a bit. The dealer told me that my tires were overinflated and they reset the system. That didn't fix it and I took it back in to find out that one of the tire sensors was faulty. They replaced it under warranty, but then again I had the stock wheels and had never swapped them.
Old Apr 7, 2006 | 10:57 AM
bedrock83's Avatar
I have the stock wheels, but 55500 miles on my car. I hate going to dealers, they try their absolute best to charge you for everything!
Old Apr 7, 2006 | 11:04 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
You're going to the wrong dealer. Mine is great!! (Jeff Haas, Houston)
Old Apr 9, 2006 | 08:12 PM
bluesman2045's Avatar
brkeen vale stem inside wheel tire will hold air if keep cap real tight can stem valve be replaced by taking tiere off or does the whole sensor have to be purchased and replaced help ]
Old Apr 9, 2006 | 08:15 PM
valve stem can be replaced. search tpms and jeep see what you can find.
Old Apr 9, 2006 | 08:44 PM
here you go.
https://www.rx8club.com/showthread.p...pms+valve+jeep
Old Apr 9, 2006 | 09:16 PM
thanks swoope got part number from jeep ill give it a try jack
Old Apr 9, 2006 | 09:18 PM
no problem, did you get my return email???? personal messageing works better for that kinda stuff.
Old Apr 9, 2006 | 09:24 PM
brand new at computer 21st century made me do it im learning thanks again
Old Apr 9, 2006 | 09:29 PM
you have a pm. you can get it buy clicking on the private message link at the top right of the frame.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
CARBONRX-8
Oct 5, 2015 03:46 PM
Forevermore
Sep 20, 2015 01:04 PM
