Odd noise when changing gears???
Old Mar 20, 2006 | 03:41 PM
Hightshoe's Avatar
'05 Titanium 6sp
I've done a few searches and found some threads on similiar problems, but Im not sure if any of them were the same thing im asking.
My question is: when I change gears from 1st to 2nd and 2nd to 3rd, about 90% of the time I get this sort of clinking/buzzing sound. Its really faint, so I didnt notice at first. You can feel it more than hear it. I dont think its really a grind. Ive had my 8 for a few months now, and its the first MT car ive owned. So is this a normal sounnd? Or should I take it in? It doesnt make the noise when changing to any other dears. Is it just the mechanical noise of another gear engaging?
thanks
Old Mar 20, 2006 | 04:27 PM
QBallz's Avatar
Mine just started doing this around 1k miles ago. I don't know if it's normal or not. I tried switching out the Gear Oil but it didn't help anything.
I'm going to try that Redline MT90 and see if that does anything now, it should be here tomorrow so I'll let you know
Old Mar 20, 2006 | 04:33 PM
Go48's Avatar
Sounds like it could be the throwout bearing, but that would likely be apparent when shifting to the other gears as well. Do you feel the "buzzing" when pressing the clutch with the transmission in neutral? Maybe just as you start to get a bit of resistance on the pedal?
Best to take the car to a dealer and have it checked out. That's what the warranty is for.
Old Mar 20, 2006 | 04:41 PM
QBallz's Avatar
I believe it's the Syncro's spinning up then meshing into gear.
Old Mar 21, 2006 | 08:47 AM
Hightshoe's Avatar
'05 Titanium 6sp
No buzzing when the car is in neutral while pressing the clutch. It mainly happens when im going from 2nd to 3rd, occasionally from 1st to 2nd. So if its the Syncro's spinning up then meshing into gear, that would make it normal? If so, isnt it odd it only does it beween two gears and not all the others? All others are like butter.
thanks for the suggestions.
Old Mar 21, 2006 | 10:03 AM
QBallz's Avatar
This happen more when the car is cold? And also is the shifting still really smooth but just has a noise?
Old Mar 21, 2006 | 11:46 AM
Hightshoe's Avatar
'05 Titanium 6sp
The noise happens regardless if the car is warm or cold. the shifting is not smooth when it happens, its almost like its being held up a little although I dont have to force it or anything. It does it no matter if I shift slow or quickly.
Old Mar 21, 2006 | 11:54 AM
stupidCivicstrixAre4kids's Avatar
its synchros nothing is wrong with your car....but to make sure go to a dealer and check the throut bearing
Old Mar 21, 2006 | 04:16 PM
Go48's Avatar
If the dealer is unable to "duplicate" your problem--which is likely--consider changing the oil in your transmission (and differential while you're at it) to a synthetic like Redline or Royal Purple. That may help with the noise and it will definitely improve shifting. There's a lengthy DIY on just that in the--you guessed it--DIY section.
Old Mar 23, 2006 | 07:07 AM
Howdy1606's Avatar
Howdy
Thumbs up
are you pushing the clutch all the way in. Also if you are trying to shift fast make sure you dont let out to soon>!>!>!
Old Mar 23, 2006 | 01:21 PM
Hightshoe's Avatar
'05 Titanium 6sp
Yes i push the clutch in all the way in. I think i have the timing down pretty good when I shift fast, so I dont think thats it.
Old Mar 23, 2006 | 06:36 PM
cjkim's Avatar
^noob
go drive another car
Old Mar 26, 2006 | 06:49 PM
Moumtz's Avatar
Let me compete his sentence for you
"go drive another car" so that you can see if other RX8's have similiar behavior. If they do, you know yours is normal
Old Mar 26, 2006 | 07:02 PM
cjkim's Avatar
^noob
i thought that was implied.
Old Mar 27, 2006 | 09:49 AM
boonyloh's Avatar
Rotorhead
i'm having the same problem as well it started around 2000kms ago tried changing a few types of trans oil... no improvement at all...
Old Mar 27, 2006 | 10:52 AM
Hightshoe's Avatar
'05 Titanium 6sp
i guess ill have to take another 8 for a drive and see if it does the same thing.
Old Mar 28, 2006 | 11:43 PM
LilGuy's Avatar
Same kind of thing, but mine I think is a little smoother than your talking about. The shift from 2nd to 3rd only, and it is smooth, but makes a low pitched sound, it SOUNDS like gears moving, or meshing, or w/e but I really am new to this stuff.
Old Mar 29, 2006 | 08:49 AM
Hightshoe's Avatar
'05 Titanium 6sp
I guess mine only does it when I shift between 3-4000 rpm's. I shift above 4 its smooth. Is that odd???
Old Mar 29, 2006 | 01:14 PM
DailyDriver2k5's Avatar
The Prototype
I don't think its your throw out bearing, throw out bearing sounds like rocks tumbling in your transmission. It doesn't sound like a buzzing sound, sorry. Could be something else, heat shield can make a buzzing sound if the its rubbing against the frame. The high vibration of the piece that is rubbing against the frame will cause a buzzing sound, especially under WOT. I would jack up the car to have a look,if not, take it to the dealer .
Old Mar 30, 2006 | 12:33 AM
Parmer8's Avatar
I'm looking through the manual and can't seem to find - throw out bearing. Is that the same as the pilot bearing?
Old Mar 30, 2006 | 07:36 AM
Go48's Avatar
No. See the attached images. The "clutch release collar" as shown in both drawings (#16-510 in the parts drawing) is what is commonly referred to as the throw-out bearing.
Attached Thumbnails Odd noise when changing gears???-clutchparts.jpg   Odd noise when changing gears???-clutchreleasecollar.jpg
Old Mar 30, 2006 | 08:32 AM
Parmer8's Avatar
Thanks for the info.
Old Mar 30, 2006 | 08:41 AM
Go48's Avatar
Sure!
Old Mar 30, 2006 | 08:47 AM
SoFL_RX8's Avatar
Former Owner
Mine has made that noise from the day IO drove it out of the showroom. Its the syncro... although it wouldnt kill you to have your throwout barring checked out at next servicing.
Old Mar 30, 2006 | 09:17 AM
Hightshoe's Avatar
'05 Titanium 6sp
Im due for my next free oil change at the dealer in 1000 miles, Ill have them look at it.
