275/30/19 Pirellis and 9.5" Hiro's are on!
Old Mar 14, 2006 | 07:29 PM
800Degrees's Avatar
Those, of course are the rears... the fronts are 245/35/19. I was pleasently surprised that the shorter sidewalls didn't make the ride noticibly rougher - it feels about the same. The total diameter of the new wheel/tire combo is 3/8" shorter than the factory 18s and 225/45s.
Attached Thumbnails 275/30/19 Pirellis and 9.5" Hiro's are on!-rear1.jpg   275/30/19 Pirellis and 9.5" Hiro's are on!-p-rear1.jpg
Old Mar 14, 2006 | 08:53 PM
lazi's Avatar
drivelinestore.com
good stuff.
Old Mar 20, 2006 | 12:09 PM
800Degrees's Avatar
Couple more...
Attached Thumbnails 275/30/19 Pirellis and 9.5" Hiro's are on!-frontside1.jpg   275/30/19 Pirellis and 9.5" Hiro's are on!-driveside2.jpg   275/30/19 Pirellis and 9.5" Hiro's are on!-driveside1.jpg
Old Mar 20, 2006 | 01:42 PM
GrRx8MaZdA's Avatar
90% Carbon-100% Power
Hey nice setup..I believe very noticeable power loss right??
I am changing my front with 225/35/19 this week just to have exactly the same diameter etc with the rear 265/30/19 i have..
Old Mar 20, 2006 | 01:46 PM
800Degrees's Avatar
Thanks... But I've noticed no power loss. The wheel/tire combo is about 3/8" smaller (diameter) than stock... so, technically, I should've gained a bit of final gearing. As to weight, I have no idea.
Old Mar 21, 2006 | 12:02 PM
GrRx8MaZdA's Avatar
The 275 tire is very much to rotate it...Try heading with an rx8 with stock wheel combo..You ll sure see you can't beat it...
Just to let you know i am not talking personally and telling you that you re slow,i have also staggered setup in 19s and very leightweighted
Old Mar 21, 2006 | 02:13 PM
800Degrees's Avatar
Okay - I see. That makes sense. I wonder - because of the significant gain in traction - if the car can now be launched harder resulting in a same as stock or better than stock set-up.
Of course, I'll admit, I'm as concered with the appearance as I am with performance. If not... I'd be driving a WRX STI
Old Mar 23, 2006 | 10:31 AM
lesper4's Avatar
T-29 years and counting
very very nice, excelent choice
Old Mar 23, 2006 | 01:00 PM
800Degrees's Avatar
Thank you!
arexatemate
Oct 4, 2015 12:36 PM
CMRine04
Sep 17, 2015 10:04 AM
20b-3rotor
Sep 2, 2015 08:54 AM
adrian-1
13
Jun 16, 2005 10:10 PM
oyester
Australia/New Zealand Forum
9
May 25, 2005 04:38 PM
