View Full Version : Best Intake For the RX-8
Evil 8
03-07-2006, 01:26 PM
I wanted to see peoples opinions on which is the best Cold Air Intake. Im thinking about getting one but dont really know which one to pick. Sound wise and Performance.
XDEEDUBBX
03-07-2006, 01:30 PM
there is no best intake, it comes down to preference. Kinda like saying, which is the best car...
Jaguar_MBA
03-07-2006, 01:37 PM
Your car comes stock with a Cold Air Intake system.
swoope
03-07-2006, 07:56 PM
intake
copy that word and paste it in the search bar.
then read, read, read.
beers :beer:
Moonrover333
03-07-2006, 09:40 PM
i own the simota/ umnitza intake and i love it seems to pull a lil better, and sounds great very loud though you can check sound clip on the umnitza website
mysql101
03-07-2006, 09:42 PM
i own the simota/ umnitza intake and i love it seems to pull a lil better, and sounds great very loud though you can check sound clip on the umnitza websiteA little off topic, but you must realize that your sig animation actually mouths, "Mo naked hoes"?
dannobre
03-07-2006, 10:16 PM
In who's lip reading world :D:
mysql101
03-07-2006, 10:31 PM
In who's lip reading world :D:this one.
XDEEDUBBX
03-07-2006, 10:33 PM
mo naked hoes it is..
Kewl
03-12-2006, 06:55 PM
So you think the intake in the 8 is a cold air intake? Good thing it is. My measurements of air temps were enough to make me change the intake. When the outside was 90 degrees the intake temps were often 130 to 135 degrees. You would think that once you get underway the temps would lower to something closer to what the outside air temp was...it doesn't. They do come down slightly, but not much. Even with the install of the REVi Ram air the temp only dropped about 15 degrees below what I was seeing before its install, so the intake air temp is still high....nothing close to what the outside temp was. If the OEM intake wasn't already cold air I would hate to think what the intake air temps would be.
Anything you can do to lower the temps...do it.
legokcen
03-12-2006, 07:16 PM
I'd rather have Mo Naked Hoes than Po Ta Toes anyday.
NgoRX8
03-12-2006, 10:19 PM
Just go for sound. Performance for an intake isn't much of a difference here. as for going cold air intake, there are only AEM, Racing Beat (w/ ram air duct), and the Mazdaspeed CAI (which isn't out yet).
cjkim
03-12-2006, 10:48 PM
and stock :]
mikefrombarrie
03-12-2006, 10:56 PM
I found the SR Motorsports intake to be very good. It works great with the racing beat air duct.
EyeBall Fixer...(o)(x)
03-13-2006, 12:00 AM
Like your pullies. How do they work for ya?
swoope
03-13-2006, 03:37 AM
really,
i find with the revi and the duct if i am moving over 20 mph the difference in oustide temp and intake temp is ~8deg f. if i am going over 100 the temp gets real close to the oat.....
this does not count if you are dealing with stop and go traffic and the whole car is a heat soak.
beers :beer:
dgrx8
03-13-2006, 11:27 AM
question for mikefrombarrie...
does the sr intake actually line up w/ the air inlet or is it like the k&n which doesn't line up???
Kewl
03-13-2006, 10:42 PM
Swoope,
Had you done any measurements before you put the duct on? With the duct I got the delta to drop by half so the temp rise is ususally only about 15 degrees over outside.
mikefrombarrie
03-13-2006, 10:50 PM
I noticed that the car revs alot quicker then before, but its not a huge gain.
mikefrombarrie
03-13-2006, 10:55 PM
I had to modify the VFAD, all you have to do is cut off the piece thats circled in red and attach it to the Racing beat air duct, the fitment is excellent!!
I am going to start my turbo install next week, so I will take some pics of the setup
swoope
03-14-2006, 04:19 PM
Swoope,
no,
got the scanalizer after the revi and duct. i am just amazed to watch the temp drop as speed increases.
beers :beer:
needmorerotors
03-16-2006, 09:42 AM
I just installed an aem intake.Noticable difference but idles rough and whisles while idling.The CEL came on once and turned off about 200 miles later.I dont know if it was related because its done that once before the intake was installed.Istallation was a pain considering that iv never been into the import scene{dawm fiberglass bumper}.Im used to my chevy.mid range sounds kinda ricy around 4k but sounds bad ass once it hits 7k-9k.metal pipes gets pretty hot for being a cold air intake.hot pipe=hot air.
VASasha
03-16-2006, 10:18 AM
I installed the AEM about a week ago. HUGE difference that you can feel, best one out there i think. It sounds great too, gives your engine a bit more "Vroom"
The install, is a pain in the ass since you have to remove the entire front bumper. The instructions say that you have to lift up the car and remove the front two wheels to do it, but I did it in my driveway without that. Took a bit longer to do it i'm sure but I still managed.
needmorerotors
03-16-2006, 10:20 AM
hey vas does your car whisle when it idles and does it idle rough.just curious
VASasha
03-16-2006, 10:27 AM
not that I have noticed. sounds like you might have an air leak or something. did you check to see if everything was tight?
the only problem I had was the first time that I fired up the engine after installing it, the car wouldn't rev past 5500 but that was because i didn't completely remove the vaccuum thing. The instructions that i got with my AEM CAI weren't the best. I think they were one of the first versions they made. I bought it on ebay about 5 months ago for $140(including shipping), just havn't had time/weather to install it till now.
needmorerotors
03-16-2006, 10:32 AM
my instruction wernt the best either and i thought there was an air leak too but check and found nothing.doesnt whisle until warmed up. some time it goes away randomly for a few minutes, and it idled rough before intake and i think it alittle worse now but im not to sure
VASasha
03-16-2006, 10:34 AM
I'll check mine throughout the day and let you know tonight if I notice anything.
VASasha
03-16-2006, 07:14 PM
I checked for it today, didn't hear any whistle. I did however, hear a really feign high pitched whine, but I think that's just the engine spooling up (or something like that). It didn't sound out of place. My idle didn't seem to have any problems, was steady at 800 RMP.
needmorerotors
03-17-2006, 01:44 AM
yeah it is more of a whine than a whisle but same thing so i guess it must be normal
earlie023
01-03-2009, 08:53 PM
got a question... when installing K&n intake... the typhoon version.... where do i insert the 2 hoses? coz it has only 1 outlet for the hose... thanks...
04RX8man
01-03-2009, 09:05 PM
performance wise u will prob see a drop in HP and TQ but it will sound different
the sound and looks is all ur gettin with an intake on this car
Never L8
01-06-2009, 09:10 PM
^WOW! This thing's back from the dead! I didn't realize it until I read the MazdaSpeed intake wasn't out yet. I was like, whaaaaat? Haha.
I have the MazdaSpeed CAI and I really like it. I didn't notice any performance improvement, but then again, I knew that when purchasing it. I love the way it sounds, though! Let's face it, though, there's not a whole lot you can do to tap power out of the rotary without going forced induction. Oh well. Way to give life back to a three-year-old thread!
Jim Sanderbeck
05-13-2010, 09:28 PM
Aye Carumba,what if i attached a 4 inch tube to the stock air box-with a drop in K&N and ran the tube or pipe to the front of the car-directly in the airstream?Any thoughts or comments.I did this with a 1986 Mustang SVO using collapsible ridgid aluminum duct and it made a huge difference in responce and power. Thanks JimS 2007 17 K blk/BLK GT 6 sp,strakes,clears and debadged.
zoom44
05-13-2010, 09:30 PM
hhaha you've already got that with the stock unit except for the drop in K&N. Its got a hose that runs into the bumper already. dont expect a huge difference in response or power
azzuro
05-24-2010, 07:13 PM
Curious if there's an intake that has less drone on the highway?
Pico
05-24-2010, 07:34 PM
^ compared to what?
