gnathen
03-06-2006, 08:35 PM
i need imput on the setup that i am about to attempt. i want to access the rear accessory plug. tap into it with a line tap using 18 awg wire. run that wire to a terminal strip mounted on my amp rack. run wire from amp and crossover to this terminal strip for 12v turn on. i want the terminal strip for extra options later. Ex. cooling fans for my amp and led lighting for amp and crossover. i would also like to know if on my crossover i can just jump the turn on wire to the +12v connection. i would really like your feed back on this.
