rx8atlast
03-06-2006, 02:09 PM
I had the liner out of the trunk over the weekend and I noticed that are vents (with soft rubber louvers/flaps) on either side of the trunk. Any ideas what they are for? Thanks.
View Full Version : Vents in trunk? rx8atlast 03-06-2006, 02:09 PM I had the liner out of the trunk over the weekend and I noticed that are vents (with soft rubber louvers/flaps) on either side of the trunk. Any ideas what they are for? Thanks. Asmoran 03-06-2006, 02:18 PM They allow air to exit the car when you shut a door / trunk. Makes it easier to shut the doors / trunk. StealthTL 03-06-2006, 02:21 PM They are the other half of your heater vent system - you can't have an outside inlet, and a three speed fan, without somewhere for the air to get out. S rx8atlast 03-06-2006, 03:27 PM Ah...that makes sense. I thought the other half of my heater system was all the heat that comes through the center console. :) Asmoran 03-06-2006, 04:19 PM That's the 1st half. When you turn on the heater, a vent sucks air from the center console and pushed it through the vents ;) |
