Questions in the name of research
Old Aug 7, 2003 | 10:38 AM
rx7gslse's Avatar
Hey all you Rx8 guys...
I've got a few questions for you guys as I start a little research into what it woudl take to get a renesis into a 1st generation Rx7..
How does the motor mount to the chassis in the Rx8? is it attached on the front cover, rear cover, housinging? If I recall it is part of a subframe of sorts that mounts to the actual body of the car correct?
Anyone got some pictures of their car up on a lift to share?
planing on using the Rx8 block/tranny.. Not so sure on the intake setup as of yet. It'll be full standalone ECU, so I don't know that I'll be able to actuate all of the vairable length intake track peices easily, and I also don't know that the engine sit low enough for the intake system to clear the hood..
Just thinking out loud.. lend any thoughts you have this way..
Old Aug 7, 2003 | 10:44 AM
rx7gslse's Avatar
2nd question..
does anyone know if these engines use the same 225mm clutch assemblie as the previous rotaries, or no?
Old Aug 7, 2003 | 10:56 AM
Sputnik's Avatar
Have you seen Yawpower's website yet? That should answer some questions at least.
---jps
Old Aug 7, 2003 | 11:31 AM
rx7gslse's Avatar
yep! I've seen that awhile ago....
Anyone with a 1st gen had better know who Paul Yaw is...
he's one of my heros
Brokegang
Jan 3, 2016 12:45 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
gnat42
Sep 16, 2015 08:47 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
