Problem with stock Bridgestone tires
Old Feb 23, 2006 | 11:14 AM
RX-Aight's Avatar
shaaaaaa...
So here it is. I've got about 3,000 miles on the RX-8 and was going to rotate the tires last night. I checked them at 1,500 when I did the first OLF and they seemed to be fine.
Well, now they are all getting really choppy on the outside edge tread. I checked the alignment and every thing is in speck except the dirver side caster was out a little. Without getting into a full-blown alignment discussion I know that caster will not cause tire wear, however toe and camber will. Toe causing choppy wear and caster causing smooth inside or outside wear.
What I don't understand is all 4 tires are getting choppy, the toe checked fine camber checked fine. Tires are not out of balance since I have never had any vibrations in the steering wheel.
Well, anyway I called Bridgestone customer support to talk to someone, took all my info etc, they called the manager of a store that is close to me. He said that he wanted to have the tires in stock when I came in to get the tires checked. I'm assuming they will replace the tires since they are going to the trouble to have them on hand when i will be there
Has anyone had any problems like this with the stock Bridgestones? Or do I need to start looking into other possibilities?
xAgyex
Jun 3, 2026 03:47 PM
SupraG
Sep 21, 2015 12:09 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
cschoeps
Aug 6, 2015 12:44 PM
