NEW 8! 2 things, are these normal ?
Old Feb 23, 2006 | 04:19 AM
Dro's Avatar
Dro
Cool NEW 8! 2 things, are these normal ?
Got my NEW 8 yesterday !
Silver w/ black lthr int.
6 speed w/ appearance & rotary acct. pkg !!!!
Juts a few questions though:
1. There is constantly air coming out of the AC vents even when its turned off ???
and
2. Its almost impossible to get it into reverse, i literally got to throw it and then jam it down as hard as i can into gear ...
Never had a new car before and this is so different from my 13b 1st gen so i wouldnt really know if these things should be goin on
thanks a lot guys
Old Feb 23, 2006 | 05:34 AM
dillsrotary's Avatar
jersey fresh
the reverse doesn't sound good..... you know you have to push down the shifting **** then move it to the six position?
Old Feb 23, 2006 | 05:35 AM
Go48's Avatar
1. Never checked for that but maybe it is passive ventilation. Fan is off? Check the owners manual.
2. It is a little difficult to shift into reverse, but it's a matter of getting the technique down. Push down on the lever, push to right and back and the will do it. After you get a few miles on the car consider changing the transmission and differential fluid to a synthetic like Redline or Royal Purple.
Old Feb 23, 2006 | 05:49 AM
Dro's Avatar
Dro
thanks yall i had no idea about pushing down on it !
as far as the AC i figured it was passive but it is in the off position sooo
well im taking it to the dealer today to have it detailed [ and to give them the rest of the money =D ] anyway ill ask about the AC
the car already had 5000 miles on it so they gave me the 1,000 $ discount
it probably still does not have the synthetic fluids though so at my first oil change ill look into getting those changed as well
but thanks though
Old Feb 23, 2006 | 05:54 AM
cjkim's Avatar
^noob
1. Stupid suggestion but, it's probably that little button that lets air in from outside is on... or off, i forget which closes air from coming in from outside.
2. Yeah, you have to push down -_-
Old Feb 23, 2006 | 05:59 AM
Dro's Avatar
Dro
I will look into it on my next break
Old Feb 23, 2006 | 06:22 AM
New Yorker's Avatar
From the Owner's Manual…
As cjkim suggested, it might be the Air intake selector. Most people—in all cars—have it set wrong. Normally it should be set to "Outside"—not "Recirculated":
"It is recommended that under normal conditions the switch be kept in the outside air position".
I can't tell you how many friend's cars I've been in where it's mistakenly set to Recirculated all the time. Recirc is for when you ride on dusty roads and don't want dust entering the car, or when you want the A/C to cool down the car fast. (That's probably why most people have it set there. But then they leave it there, thinking it's the normal position.)
And yes, you have to push down for reverse, but also note this:
"If shifting to R is difficult, shift back into neutral, release the clutch pedal, and try again." I think that's true for many manual transmissions.
Old Feb 23, 2006 | 06:54 AM
Dro's Avatar
Dro
i checked it on break and it goes in smooth as **** [R]
as far as recirc. i think i have it selected to outside as opposed to the one that looks like a loop
would that explain the passive airflow ?
Old Feb 23, 2006 | 06:55 AM
Dro's Avatar
Dro
also the guy at the dealership told me before i turn it off to rev it up and when it comes back down as it gets to 2K to turn it off ... is that right ? i never had to do that on the 13B, should i have been doing it lol ?
thanks for the help though i love this ****** forum
Old Feb 23, 2006 | 11:01 AM
Dro's Avatar
Dro
word thanks
Old Feb 23, 2006 | 11:10 AM
This reminded me a about a thread i read back in 03..haahha..
Old Feb 23, 2006 | 11:13 AM
zoom44's Avatar
Originally Posted by Cool-Blue-Dad
If you set the vents for windshield+floor then
his AC will be on all the time
Dro's Avatar
Dro
lol what can i say im an 8 n00b
Old Feb 23, 2006 | 11:18 AM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
Is your Sunroof open? I notice that if you open that, the vents will go on even if the car's AC isn't on.
Old Feb 23, 2006 | 11:31 AM
Dro's Avatar
Dro
i live in florida
Old Feb 23, 2006 | 11:45 AM
Chrisbert's Avatar
I set mine to recirc, fan off, windows cracked. If I used fresh air, it gets heated up by the car and toasts me.
Old Feb 23, 2006 | 11:48 AM
Dro's Avatar
Dro
I never use AC anyway im poor especially now that I have a brand new RX8 GT w/ all upgrades aside from NAV
Old Feb 23, 2006 | 11:50 AM
cjkim's Avatar
^noob
actually, i believe most cars do that
Old Feb 23, 2006 | 11:54 AM
ZoomZoomH's Avatar
Mulligan User
the vents don't 'go on' (eg the air fan is not turned on), it's just natural air movement/ventilation as a result of your car being in motion, and your cabin having a lower air pressure than outside, thus the air outside is being 'sucked in' to neutralize air pressure.
Old Feb 23, 2006 | 12:00 PM
Dro's Avatar
Dro
har har
i suppose my 7 was not "most cars"
unless this is specific to 6 speeds
whaaaaaaaaaaaatever
Old Feb 23, 2006 | 12:03 PM
ZoomZoomH's Avatar
Mulligan User
har har
whaaaaaaaaaaaatever
i think he was talking about your air vent question... which does operate the same on most cars... even on your 7....
Old Feb 23, 2006 | 12:06 PM
Dro's Avatar
Dro
oh lol the 7 did not have an AC compressor and i never noticed anything like that
oh well though
do pre-she-ate the help either way
Old Feb 23, 2006 | 05:00 PM
Marc_H's Avatar
Hit the button to recirculate the air and turn the fan to -0-. No air will come through the vents.
I had the same problem with reverse when I first got the car last June. I pushed down and threw it to the extreme right, but it was hard to get it in gear.
It loosened up with time.
