Will EVO VIII Brembos fit on the RX-8?
Old Feb 23, 2006 | 01:48 AM
velocityredRX-8's Avatar
I have a friend who is trying to get rid of his brembo brakes that come stock on an EVO. I was wondering if it is possible to somehow fit this big brake kit on the RX-8? If anyone can chime in and give some input as to whether they would fit, let me know. Thanks.
Old Feb 23, 2006 | 07:46 AM
Rx7Roadster's Avatar
My spoon is too big
With enough time and money yes. You better know what you are doing if you paln on making brackets to bolt them on.
Old Feb 23, 2006 | 09:30 AM
RX-Aight's Avatar
shaaaaaa...
Why not call Brembo, or email then for info. If anyone would know I would like to think they would.
I would have to think that they could easly cross reference part numbers to see if they would work on your application.
Old Feb 23, 2006 | 09:39 PM
ill try calling them tomorrow and see if they will work.
Old Feb 27, 2006 | 10:05 AM
florent75's Avatar
Hi
brembo center size : 69 mm
rx8 size : 72 mm
for both : 114,3
so you just need to "enlarge the brembo rotor and it will fit on the rx8 perfectly
but ...
you can not put the standard caliper ... to small
I'm actually monting thoses rotors with brembo caliper (doing the adaptation actually)
I will probably sell some kit after .. if good results and some guy interessed ...
the big advantage : you're in 32 mm large versus 24 mm
no problem on track ...
Old Feb 27, 2006 | 06:42 PM
zaglo6204's Avatar
mine's better
our stock brakes are awesome, so unless youre just going for that attractive brembo painted caliper, i dont think it would really be much of an upgrade, if not a 'downgrade'.
Old Feb 27, 2006 | 08:09 PM
Mazdaspeed RX8 ver2's Avatar
i agree with you zaglo, the stock brakes are excellent. The only thing that would probably be needed to change would be the pads.
Old Feb 27, 2006 | 08:15 PM
zaglo6204's Avatar
mine's better
i was only gonna mention the pads if he asked...haha. but thanks for the support.
Old Feb 27, 2006 | 08:33 PM
Haha, no problem!
Old Feb 27, 2006 | 11:06 PM
terrypk1's Avatar
yeah. agree. rx 80-0 =194 feets better than S2000, EVOs, and even the great lutos elise.
interesting fact isn't it.
so i wouldn't borther with the break system except the pads.
Old Feb 28, 2006 | 12:32 AM
florent75's Avatar
yes for ... normal use
I kill my rotors (veil) on tracks : overheat and the space : 24mm is to small so ... overheat and veil
we are 6 to have the same problem doing track.
I agree rx8 braking is perfect
I'm only looking for bigger disk (larger) to not have overheat and track and be afraid to kill the rotors.
Old Feb 28, 2006 | 01:04 AM
terrypk1's Avatar
i will give some credits for killing the rotors. WOOO. how many laps had you done before the rotor died?
you are a perfert car enthu. love you man.
stickmantijuana
29
Mar 25, 2016 09:58 AM
codesterb91
Nov 16, 2015 05:57 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
ktec
Sep 19, 2015 08:58 PM
motohegg
Aug 23, 2015 08:14 AM
