Iron Plates, why still Iron?
Old Feb 21, 2006 | 01:55 PM
Brice-RX8's Avatar
I searched but didn't find anything I believe that answers my question. How come the plates in between the rotor housings are still iron, but not make the whole engine out of aluminum? Maybe even make some sections with magnesium in it like BMW does now.
Old Feb 21, 2006 | 02:07 PM
Red Devil's Avatar
Cost of production is my only answer. This is a gripe I've commonly had also. A lot of weight could be saved by doing this.
I'd heard the reason for iron rotors is because of the properties of the metal and the process by which the rotors are cast. Also, if the rotor is too light perhaps it would be harder to generate torque? I'm really not sure about that, though.
Old Feb 21, 2006 | 02:12 PM
ZoomZoomH's Avatar
Mulligan User
metallurgy probably have a lot to do with it... the rotary engine is an interesting 'sandwich' of all types of metals, perhaps Mazda found a 'sandwich combo' that provides the best durability/performance within a set cost??
Old Feb 21, 2006 | 02:25 PM
Brice-RX8's Avatar
I wonder if heat has to do any with it, now that I think more about this.
Old Feb 22, 2006 | 08:30 AM
Brice-RX8's Avatar
Any of the rotary guru's have any thoughts on this?
Old Feb 22, 2006 | 09:59 AM
neit_jnf's Avatar
cost...
Racing Beat sells Aluminum $ide plate$ for only $1200 EACH
http://racingbeat.com/resultset.asp?PartNumber=11072
Old Feb 23, 2006 | 12:36 PM
griffe's Avatar
Isn't it because iron withstands heat much better than alluminum? Aluminum warps in intense heat. And rotary engines produce a lot more heat than an engine with cylinders.
Old Feb 23, 2006 | 01:29 PM
Rx7Roadster's Avatar
My spoon is too big
Steel warps too. Cost is the most likley factor. Aluminum is much more expensive then steel. Heat capacity and wear resistance probably have something to do with it as well.
JimmyBlack
273
Feb 10, 2020 10:23 PM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
coolcars44
Sep 24, 2015 05:47 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
