RP vs SR (correct me if anything wrong) Urgent place order today
Old Feb 20, 2006 | 04:20 PM
t_zac's Avatar
t_jzach1108
i am consider to get RP ‘Supercat’ Mid Pipe or RX-8 Midpipe with silencer (SR).
What is the difference between them. are they legal is my most concern.
i am going to get one with the RB exhaust.
And i can't find the sound clips with this combination in the research...does it sounds much lounder??
Since i DON"T want to be so loud....the unquie rotatry sound is great to me.
every idea and suggestion is appreciated.
Old Feb 20, 2006 | 05:18 PM
Fanman's Avatar
I had/have both. I had the SR Motorsports unit (w/the additional resonator added on) and it was a very nice piece. Unfortunately, it was popping/backfiring when I put my turbo on, so I pulled it off and sold it. I swapped out the the fuel management unit, and that allowed me better control of the A/F ratio and I was able to dial out the backfire. I have the Rp unit on my car now. It is definitely louder (no additional resonator), but still very well made & supposed to give a bit more hp. I would say if you want it quieter then go for the SR unit, and ask them to add on the additional resonator.
Old Feb 20, 2006 | 05:20 PM
t_zac's Avatar
t_jzach1108
thz for the reply, one more thing, are they legal??
wht the RX-8 High Flow Catalytic Converter use for??
Old Feb 20, 2006 | 07:34 PM
NoTears316's Avatar
Shock and Awe
I also used both. I had the SR installed for over 2 years, and then it fell apart on me. It started to rattle, then threw a CEL as it was restricting airflow. I replaced it with the RP Supercat. The RP is a lot louder than the SR unit, but it is well built and I have had no problems with it (only been installed less than a month now).
Old Feb 20, 2006 | 07:35 PM
NoTears316's Avatar
Shock and Awe
I passed emissions with the SR unit, haven't tried yet with the RP.
Old Feb 20, 2006 | 08:29 PM
Fanman's Avatar
Yes, they won't set off the sniffer, but if the inspector knows what he is looking for (not likely) then you are not allowed to change out a functioning emissions part. You might fail the visual inspection part, but there is a very, very slim chance of that.
Old Feb 20, 2006 | 09:50 PM
t_zac's Avatar
t_jzach1108
how come this happen?? is there any thing wrong with it individually??
does it smell sting with the SR unit or RP either??
as for me i don't want it so loud, moreover, i do not plan to add a turbo on my 8.
so i guess there is nth worry about the back fire.
stand away from the noise, which one will you pick??
and which one give out more power?
Old Feb 20, 2006 | 10:35 PM
zaglo6204's Avatar
mine's better
the RP is supposed to give more power, but its not much to begin with. can't help you with quality though...
i'm in the market for a high flow cat as well, & i think i'm going to go with the RP unit some time this spring.
Old Feb 20, 2006 | 11:22 PM
IZoomZoomI's Avatar
Boost needed
you should copy and paste this response, it seems like this question is asked every two weeks
Old Feb 21, 2006 | 09:06 AM
NoTears316's Avatar
Shock and Awe
This thread might help...
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/sr-motorsports-high-flow-cat-failure-81980/
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
ShadowGryphon
Aug 23, 2015 02:46 PM
dafiltafish
Aug 21, 2015 06:56 PM
thewatcher101
Jul 27, 2015 09:44 PM
