Donny Boy
09-28-2002, 10:56 AM
I would like to see at least 8" rim width up front and at least 9" rim width in the rear.
What do you think??
What do you think??
View Full Version : Rim width Donny Boy 09-28-2002, 10:56 AM I would like to see at least 8" rim width up front and at least 9" rim width in the rear. What do you think?? Hercules 09-28-2002, 11:14 AM No. Imagine the cost of replacing tires. Donny Boy 09-28-2002, 02:25 PM Yes, maybe. But look at how good it will look. Aren't tires available individually? I mean, usually we but 4 at a time, but 2 at a time should not be that financially prohibitive. Oh well. Sputnik 09-28-2002, 02:58 PM On a lightweight car, it would be overkill, worse for foul weather, and add unsprung and rotational weight. No, thank you. ---jps zoom44 09-28-2002, 03:50 PM sputnik, i agree with you that it seems like overkill and would add too much weight but why would it be worse in foul weather? because of the twwo different widths or just wider alltogether? :confused: Buger 09-28-2002, 04:16 PM Less weight over larger contact patch = greater chance for slippage on snow. Rich 09-28-2002, 04:47 PM Given the same inflation pressure, wider tires don't give a bigger contact patch, just wider. zoom44 09-28-2002, 05:12 PM i'm glad you're here today rich. so why would the wider tires worse in bad weather? sheylen 09-28-2002, 05:19 PM Originally posted by Rich Given the same inflation pressure, wider tires don't give a bigger contact patch, just wider. Can you please explain this. I would think that a wider tire would have a greater contact area (surface). But who am I. Thanks Rich 09-28-2002, 05:39 PM I'm sure there's a link out there that explains it better than I can, but a quick search didn't turn up a good one. So, I'll give it my best shot. Here's what I wrote in another thread (http://www.rx8forum.com/showthread.php?s=&threadid=531): Many people think that bigger tires have a bigger contact patch. This is not true. The size of the contact patch is related to the pressure in the tire, the weight that is supported, and the strength of the sidewall. Let’s ignore the sidewall effect for a moment. The pressure in the tire is measured in pounds per square inch (or the metric equivalent, if you live in a civilized country). What does that pounds per square inch measurement really mean? If each tire is supporting ¼ of the 3000 lb. weight of the car, that’s 750 lbs. per tire. If the pressure in the tire is 30 lbs. per square inch, that’s 25 square inches of contact space. This does not change no matter what the size of the tire! If the tire is 6 inches wide, the contact patch will be a hair over 4 inches long. If you stick 12 inch wide tires on, the patch will be about 2 inches long (We’ll get more into this later). Stiff sidewalls can hold up a bit of the weight, so the contact patch will be less than is calculated here, but that is clearly a secondary effect. If that didn’t make sense, try this example. Picture an uninflated balloon. If you set it flat on a table, it will have a fairly large amount of surface area touching the table, because there’s very little pressure in the balloon. Now if you blow it up so that it’s really really full (lots of pressure), only a very small part of the balloon will be in contact with the table. Now, press down with your hand on the balloon. More of the balloon touches the table. You could use this balloon as a scale, if you wanted! All you’d need is the size of the part of the balloon that’s in contact with the table and the pressure in the balloon. Neat! Does that make sense? If not (and I haven't bored you too much), I can try again. Sputnik 09-28-2002, 07:48 PM Originally posted by Rich ...What does that pounds per square inch measurement really mean? If each tire is supporting ¼ of the 3000 lb. weight of the car, that’s 750 lbs. per tire. If the pressure in the tire is 30 lbs. per square inch, that’s 25 square inches of contact space. This does not change no matter what the size of the tire!... Ahhh, Grasshopper is missing one very important variable: volume. His balloon is full of hot air. Let's take the baloon example again! Take two different sized ballons, and fill them to the same pressure. Balance the same book on each, and see how big the "patch" on the bottom is. You will find that the bigger balloon has the bigger patch. The basic thing is that with the same weight and the same tire pressure, you will basically compress the air in the tire X percent. There are many minor variables that also affect this, but that's the basic formula. So, to make an easy example to show how the numbers work out (this is in no way scientific, just a basic example), let's take two tires. Each has the same tire pressure. One has a volume of 40 cubic inches, and the other has a volume of 60 cubic inches. Let's say that with our pressure, the compression will be 25%. That means that with the weight on those two tires, the smaller tire will be compressed to 30 cubic inches, a change of 10 cubic inches, while the bigger tire will be compressed to 45 cubic inches, a change of 15 cubic inches. A bigger change in air volume means a bigger contact patch. Those of us who design subwoofer enclosures know that the bigger the enclosure, the more "give" that the supporting air has. So, when we adjust the enclosure size, we adjust how much support the sub gets from the enclosure. ---jps Sputnik 09-28-2002, 07:55 PM Originally posted by zoom44 sputnik, i agree with you that it seems like overkill and would add too much weight but why would it be worse in foul weather? because of the twwo different widths or just wider alltogether? :confused: The two different widths would hurt handling performance in dry and wet, because the car is a 50/50 balance. As far as foul weather, wider tires will make you hydroplane quicker, and won't have the same p.s.i. in the contact patch itself (it will be bigger), and so it doesn't do as good of a job in forcing the tire down to the pavement, and the water/snow out. There is a point of diminishing returns, mind you, but generally, putting the same tire, but wider, hurts a little in heavy water/snow. ---jps Rich 09-29-2002, 12:06 AM Originally posted by Sputnik Ahhh, Grasshopper is missing one very important variable: volume. His balloon is full of hot air. No need to get insulting, if you're claiming that I'm just blowing "hot air". If I'm wrong I'll admit it. If your intent with that statement wasn't to simply insult, I apologize. If it was, get a friggin' life guy. Originally posted by Sputnik The basic thing is that with the same weight and the same tire pressure, you will basically compress the air in the tire X percent. There are many minor variables that also affect this, but that's the basic formula. So, to make an easy example to show how the numbers work out (this is in no way scientific, just a basic example), let's take two tires. Each has the same tire pressure. One has a volume of 40 cubic inches, and the other has a volume of 60 cubic inches. Let's say that with our pressure, the compression will be 25%. That means that with the weight on those two tires, the smaller tire will be compressed to 30 cubic inches, a change of 10 cubic inches, while the bigger tire will be compressed to 45 cubic inches, a change of 15 cubic inches. A bigger change in air volume means a bigger contact patch. Red Herring. The theory is correct, but in practice it's not a large enough effect to make any difference. The tires simply don't compress enough for this to become a factor. The numbers you used are so exagerated in relation to automobile tires, that they are very misleading. Long before you have to worry about this, the sidewall stiffness comes into play, and you've got that to worry about. Your point is at best a third order effect, if that. Here are some links, : http://www.howstuffworks.com/question506.htm http://www.ibmwr.org/otech/tirestuff.html : " Experimental data indicates that the net pressure distribution at any point in the contact patch depends primarily upon tire pressure. " http://www.insideracingtechnology.com/tirebasics1,htm.html "A tire inflated to 30 pounds per square inch (psi) loaded with 300 pounds (lb) flattens to a contact patch of 10 square inches (in2)." Originally posted by Sputnik Those of us who design subwoofer enclosures know that the bigger the enclosure, the more "give" that the supporting air has. So, when we adjust the enclosure size, we adjust how much support the sub gets from the enclosure. ---jps Yep, I've done the same thing. Well, actually bass guitar speakers. This is correct, but again, while it's a primary consideration in this realm, it just doesn't come into play in tires, except as an exceptionally minor factor. Here are some more links, and I'm done with this thread. It's been argued to death so many places, that I'm sick of the argument. These threads ought to offer a few hours of reading with all of the links, and there's enough information for anyone to come to their own conclusion. No need to re-hash it here. http://www.miataforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=004557 http://www.miataforum.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=005169;p=1 fuz 09-29-2002, 12:55 AM Omg, this is such an inane question I can't gather the energy to write out a decent reponse. 225s are plenty fine thank you. Given that this is a sports car, I'd run though tires at a good rate. Paying nearly $200 per tire is not going to make me happy. Wet weather, you need to have enough pressure to cut though the water to grip the road. Pressure=force/area. Given the same amount of force (weight) and a greater area (tire), you have less pressure on the road. If you can't cut though the water, you hydroplane. If you can't bite hard enough into snow/mud, you spin. sheylen 09-29-2002, 02:08 AM Originally posted by Rich I'm sure there's a link out there that explains it better than I can, but a quick search didn't turn up a good one. So, I'll give it my best shot. Here's what I wrote in another thread (http://www.rx8forum.com/showthread.php?s=&threadid=531): Does that make sense? If not (and I haven't bored you too much), I can try again. Thanks very hevy stuff, but it din't bore me. Thanks man!:cool: Rich 09-29-2002, 08:24 AM Ok, I realized this morning that my last response sucked. That'll teach me to post after getting back from the bar (only 1 drink!) and after midnight... Anyway, here are the 3 things I thought of upon waking this morning. 1. Let's assume you're right, Sputnik. The tire with larger volume (wider, in this case) has a larger contact patch. What happens when you plus size? When you plus size, you dramatically reduce the volume in the tire, so each time you plus size, the contact patch gets smaller! Do you believe that this happens? 2. Back to your version of the balloon example. Why is the contact patch in the smaller balloon smaller? Because the air is compressed, yeilding a higher internal pressure. The contact patch times the pressure still yeilds the weight of the supported item for both balloons. So, since I said that we assume the pressure in each tire is equal, your own version of the balloon example agrees with what I said, we just diasgree on the meaning with regards to the tires. My stated assumption was that the pressure in the tires must be equal. So if you are correct that the volume increase results in less compression of the air, which leads to a lower relative pressure, then we're talking about different things. I would say to increase the pressure in the wider tire to match that of the smaller tire and the contact patches would be the same. 3. Last, I made an unsupported statement that the compression of the air in the tires would be minimal ("The tires simply don't compress enough for this to become a factor. The numbers you used are so exagerated in relation to automobile tires, that they are very misleading."). I can test this in a couple of weeks, even though my comments in #2 make it a moot point. I'm going to be mounting my snow tires, and I can check the air pressure in them before and after I mount them. If your belief that the compression of the air in the tires is a significant factor, the pressure should be a few PSI higher when mounted than when sitting on the ground. One last thing, I don't want anyone out there to read this and think about lowering the pressure in their tires to get a larger contact patch, and therefore increase grip. That's not how it works! There are a whole host of other issues that effect tire pressure choices, including heat, rollover of the sidewall at the limit, efficiency, and ride quality. If you drop the pressure in your tires, you'll actually deform the tire and get less grip than if you had them properly inflated. This point that I've been discussing is limited to simply the size of the contact patch relative to wheel width. As for wider tires being worse in bad weather, I'm not as sure on that, so I won't offer an opinion. The explination (for the rain) that seems to make the most sense to me is as follows (link (http://www.reidstires.com/reids/PZeroSystem.cfm)): "With wide front tire fitments the volume of water confronted is increased and the distance required to drain water laterally across the tread pattern is greater. The potential to aquaplane is consequently higher." Quick_lude 09-29-2002, 09:32 AM The contact patch doesn't change area wise with wider tires, it only changes shape. A larger rim width doesn't necessairly mean you have to go with a wider tire. 205/50/16 tires for example have a range or rim widths that are acceptable to use. Wider rims would reduce sidewall flex and improve lateral handling if used with same size tire no? Rich 09-29-2002, 09:35 AM That's how I understand it, Quick_lude. However, you're getting into an area that I don't claim to understand fully. Sputnik 09-29-2002, 11:11 AM Originally posted by Rich 1. Let's assume you're right, Sputnik. The tire with larger volume (wider, in this case) has a larger contact patch. What happens when you plus size? When you plus size, you dramatically reduce the volume in the tire, so each time you plus size, the contact patch gets smaller! Do you believe that this happens? That depends on what you mean by "plus size", as in it could mean doing a couple of things. My main point was between two tires with the same wheel diameter, same final circumference. Only the widths would change, henceforth the volume will increase. As for the "numbers" in my example, they were not accurate. I just put numbers to the "formula" to show how things would change, and I exagerated so that it was clear. That's what I tried to get across in my post, anyway. If the air compressed 25%, then you'd be running around on the rims. If measured accurately enough, the pressures in your snow tire test should not as big of a difference as a few psi. I did not say that a volume increase resulted in less compression of air. ---jps zoom44 10-01-2002, 12:33 PM Originally posted by Rich "With wide front tire fitments the volume of water confronted is increased and the distance required to drain water laterally across the tread pattern is greater. The potential to aquaplane is consequently higher." now that is something i can understand. that makes complete sense thank you. zoom44 10-01-2002, 02:17 PM and now we know that they will be 18" x 8" :) Grimace 10-01-2002, 03:38 PM Guess I'll have to set aside some money for tires... or morgage something... Quick_lude 10-01-2002, 03:48 PM Originally posted by Grimace Guess I'll have to set aside some money for tires... or morgage something... No kidding.. 18" high performance summer tires are about $400 Cnd each.. Yikes.. Maybe I can ask for 16's or just order it without the wheels and buy my own 17's. :D MikeW 10-01-2002, 06:10 PM I would prefer that the 18" are made part of a 'sport' group (225/45 18 front and 255/40 18 rear on 7.5 and 9.0 inch widths) and 17's with 225/50 17 all around are standard on the RX-8.(on 7 inch widths) The benefits of symmetric tires are ease of rotation (not that a 50/50 rear axle drive car will (should) have very different tire wear rates) Sputnik 10-01-2002, 07:34 PM Originally posted by MikeW I would prefer that the 18" are made part of a 'sport' group (225/45 18 front and 255/40 18 rear on 7.5 and 9.0 inch widths) and 17's with 225/50 17 all around are standard on the RX-8.(on 7 inch widths)... Why do you want to stagger widths? What do you think that would accomplish? Without even considering replacement cost, I'm looking at the very low profile tires on the 18 inch wheels (look at some of the recent "spy" shots), and I'm getting nervous. I want a little "give" in the tire, so that the rubber can keep a decent grip on the street surface with the imperfect roads we have. Not that I'm saying it won't work simply due to a couple of pictures that I've seen. I'm just getting a little nervous. ---jps Grimace 10-01-2002, 08:42 PM I posted this in a really old thread, but it seems appropriate to bring it up now (edited for brevity). These are different tire sizes, in 16" and 17", that are approximately the same height as the tires we have been told are coming on the car (225/45R18). If you are plus-sizing (or in this case, minus-sizing) your tires/rims, you should stay within 1" of height of the original tires meant for the car, or else handling, braking, ride quality, etc. deteriorates. Ideally, you should keep within 0.5" to stay on the safe side. Ok, so a 225/45R18 setup has an overall height of 25.97". Some tire sizes that come close in 16" sizes: (Note, I'm assuming a max width of 225 mm to avoid rubbing) 205/60R16, height 25.69" --> 60 series tires = mushy response 215/55R16, height 25.31" --> also mushy, plus this isn't a popular size 225/55R16, height 25.74" --> mushy 225/50R16, height 24.86" --> too short, you lose over 1" of ride height For fun, lets try 17" sizes: P205/55R17 = height 25.88" P215/50R17 = 25.46" P225/50R17 = 25.86" Quick_lude 10-01-2002, 09:40 PM Staggering widths depends on suspension design.. It helps control oversteer afaik.. A lot of rwd sports cars have staggered wheels/tires.. Corvette, Porsches, S2000's.. Sputnik 10-02-2002, 09:16 AM Originally posted by Grimace I posted this in a really old thread, but it seems appropriate to bring it up now (edited for brevity). These are different tire sizes, in 16" and 17", that are approximately the same height as the tires we have been told are coming on the car (225/45R18).... Ya know, looking at the numbers has made me realize that I was getting caught up in the pictures after all. A 225/45 sidewall height is actually what I've found to be the perfect medium for me. The bigger wheels and quality of the "spy" shots made it look different. Okay, I'm happy with the 18s again... ---jps PatrickB 10-02-2002, 12:05 PM Originally posted by Sputnik Ya know, looking at the numbers has made me realize that I was getting caught up in the pictures after all. A 225/45 sidewall height is actually what I've found to be the perfect medium for me. The bigger wheels and quality of the "spy" shots made it look different. Okay, I'm happy with the 18s again... ---jps Heh. The Road and Track article has been quoting 18x8 225/45R18s since it came out. A quick check at tirerack.com... tires in this size (besides cheapo continentals) are $187 Bridgestone Potenza Pole Position, $193 Pirelli PZero, $211 Bridgestone Blizzak winter tires, and $251 Michelin Pilots. -Patrick Renesis Rex 10-06-2002, 03:20 AM i have no problem with 18x8 because i'll just be buying Kumho Supra Ecsta 712.... the current price for a Kumho Ecsta Supra 712 235/40-18 is $125 US. and they're such great tires, too... Quick_lude 10-06-2002, 12:27 PM Originally posted by Renesis Rex i have no problem with 18x8 because i'll just be buying Kumho Supra Ecsta 712.... the current price for a Kumho Ecsta Supra 712 235/40-18 is $125 US. and they're such great tires, too... The are not as good as the Bridgestone Pole Position, Pirelli P7000Z, Toyo T1-S or Michelin Pilot. A good tire for the money but not the best. Renesis Rex 10-07-2002, 12:27 AM not the best by far, that's agreed. if i was gonna pick my favorite tire in general it would be the Potenza S03's..... yummy tire. Quick_lude 10-07-2002, 10:57 PM Originally posted by Renesis Rex not the best by far, that's agreed. if i was gonna pick my favorite tire in general it would be the Potenza S03's..... yummy tire. Yup me too.. expensive though.. I've also heard good things about Pilots and BF KD's. fuz 10-07-2002, 11:45 PM I dunno if I can stomach blowing though $800 (+ installation) in tires every 20k... :eek: I guess that'd be funny, either me burning my 325i at every turn, or driving an RX-8 like a granny. :D R.Cade 10-08-2002, 11:45 PM I like wider tires myself. I had 245s all the way around on my 3rd gen 7, the orginal Toyo Proxies and they where awsome. Will 245's fit on an 8 inch rim? I'm hoping the bolt pattern/offest will be the same as the 7, cause I got a nice set of 18x10's waiting for it already :P Rexman 10-29-2002, 03:55 PM 245's all the way around will be awesome. The original 225's are good tho. RedRotaryRocket 10-29-2002, 05:17 PM Rich, While your discussion of tire pressure / vehicle weight = contact patch is correct, your conclusion that the contact patch is ultimately the same is dependent on the assumption that the tire pressure stays the same when going to a wider tire. Every tire has an optimum pressure for a given load. We all know that if you put too much air in your tires, you get more wear in the center... this is because the increased pressure has reduced your contact patch and are only riding on the center of the tire. Therefore, it is easy to see that even with the same tire, the contact patch is variable dependent on the pressure you are running. The reason a wider tire provides a larger contact patch, as I've always understood it, is that the optimum tire pressure for a wider tire is lower than the optimum pressure for a narrower tire. Since the operating pressure will be lower, the tire must have a larger contact patch to support the vehicle weight. This is how I've always understood it anyway. If this is incorrect, I'd appreciate some enlightenment. EDIT - Oops! Somehow I missed a whole page of this thread...it looks like you guys have already discussed this....nevermind me..... wakeech 10-29-2002, 06:11 PM 225's are "good"?? wow... too much rubber for me... if i ever get an 8, or (more probably) an FD, i'd be downsizing the rims a cm or two... maybe... for sure on the winter set though... Beemer 10-30-2002, 12:22 PM As for the tire choise, let me help a bit. My dad sells tires so we have quite some experience with some brands and models. The best tire at the moment is the Michelin pilot sport. And second best very close to the Michelins are the Bridgestone potenza S02-03's. Other brands are more average except Continental because they can make the most kilometers/miles. A brand I sure would dissuade is Pirelli. They have an average grip but excessive wear and they make the car very nervous. I have to say, I don't know about Yokohama's but I've heard they're also pretty good. About the width issue: You could compare with skates on ice. The sharper they are, the better they have grip on a skiddy surface. So when it rains, your tires have to keep grip by cutting through the water (thats also why they have ribs, to cut and to guide all the water around the contact surface). When the tire is wider, it also has to process more water, not in the length, because when you're driving, the length is continuously growing, but in the width. That's why rally cars also use smaller tires in bad weather conditions. I hope this can help a bit, feel free to correct me :) wakeech 10-30-2002, 03:09 PM exactly my point Beemer... pelucidor 10-30-2002, 04:42 PM Originally posted by Beemer A brand I sure would dissuade is Pirelli. They have an average grip but excessive wear and they make the car very nervous. Spot on anlysis for Pirelli (at least for some models). I got a great deal on a set of Pirelli P7000 Supersport (all-season) - but they are absolutely awful and in hindsight not worth the savings. The original Goodyear Eagle GS-D summer tires (not a well-regarded tire in it's own right) were noticeably better - even my wife can easily tell the difference and is nervous about driving with these new tires in the rain. Quick_lude 10-30-2002, 09:33 PM Really? I've got the Pirelli P7000 Summer version and they are great. Dry and wet, not too loud.. Grip like mad at the track, in the rain too! True treadwear is 160 :( :eek: but I got a good deal and unfortunately there is a tradeoff between grip and treadwear usage.. :( pelucidor 10-31-2002, 04:39 PM It could be that there is a huge difference between the all-season (which squeal too easily and feel nervous in the rain - the TC kicks in much too often) and the summer versions. Just after I got the new tires I had to move from NJ to Houston, where summer tires all year round would have been fine. Typical. DakarM 10-31-2002, 05:42 PM staggered size would suck. my current car has stagger size. 7.5 front and 9 rear. The difference in the tire sizes generates too much understeer and my car is 50/50 and weighs ~3100pounds (wet including driver). I know a few folks who have gone to 235/45 all around to eliminate understeering and be more competitive in autox. Also Kumhos are good street tires, but for track/autox they are not very good. Many people have commented that they get wayyyyy to greasy and also chunks of tires coming off is not very good either. 18X8 sounds good to me, 17x8 would be even better. |
