Can the OEM flywheel be shaved?
Old Feb 19, 2006 | 12:33 AM
devious12's Avatar
Flame Thrower
Can the OEM flywheel be shaved? I did a search and came up with nothing. Anyone do this or know about it?
Old Feb 19, 2006 | 11:37 AM
hondasr4kids's Avatar
Is not a good idea to shave the stock flywheel. The flywhel is part of the balancing of the e-shaft. When you get a lighter flywheel it comes with a balancer weight that come in the automatic motors.
Old Feb 19, 2006 | 12:15 PM
Bart!'s Avatar
RAWR!@#
Yes, its absolutely fine to cut the stock flywheel. I did mine, works well.
Old Feb 19, 2006 | 01:55 PM
Mazda recommends replacing it
Old Feb 19, 2006 | 02:08 PM
Old Feb 19, 2006 | 09:46 PM
devious12's Avatar
Flame Thrower
Sorry my fault I wasn't specific enough. I have a brand new flywheel coming in the mail this week from www.dasio.com I wanted to lighten the flywheel for better performance. I know others who have done it on different cars and they were rebalanced during the process. I was curious if anyone had done this or knows how much can be shaved off for weight savings?
Old Feb 19, 2006 | 10:53 PM
yiksing's Avatar
the giant tastetickles
Just make sure its balanced, you wouldn't wanna be sliced in half if it breaks loose.
Old Feb 19, 2006 | 11:04 PM
zaglo6204's Avatar
mine's better
really scary thought though.....ive pictured it in my head before, & its kinda messy. ewwwwwwwwwwwwwwwwwwwwww....good luck with it though, it should be pretty sweet if you can pull it off well enough.
Old Feb 19, 2006 | 11:51 PM
why didn't you just buy a lightweight flywheel in the first place?
It can be done, you'll pay a lot more to do it that way though and the results may not pan out well ...
your link isn't valid either
Old Feb 20, 2006 | 12:37 AM
devious12's Avatar
Flame Thrower
Try that, http://www.diasio.com/
Was just a thought someone mentioned 75.00 to have the work done. But that's just word of mouth who knows if it was just bs.
Old Feb 20, 2006 | 06:10 AM
ah, you got a new one for a reduced price
I doubt anyone will do it in the US for that price, these guys charge $180 but are located in Birmingham, AL. I suppose it comes down to how much they can remove, $75 would hardly cover the setup labor
http://www.paeco.com/index.php
Old Feb 21, 2006 | 10:19 PM
devious12's Avatar
Flame Thrower
Yah dirt cheap! I think I'll just stick with installing it correctly and not worry about shaving it down. Thanks for the input though.
Old Feb 24, 2006 | 08:54 PM
Davey's RX-8's Avatar
Red headed stepchild
Obligatory Gillette Fusion razor comment.
Old Feb 25, 2006 | 10:37 AM
DARKMAZ8's Avatar
"Call me Darkman"
every rotary shop I know of is totally against it.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RXFEVER
Aug 29, 2018 10:14 AM
Quiggs321
Sep 30, 2015 05:34 PM
xAgyex
Sep 28, 2015 08:54 AM
