possible way to increase idle speed?
Old Feb 11, 2006 | 05:53 PM
olddragger's Avatar
Smile possible way to increase idle speed?
Ok everyone,
I have always wanted this engine to have a higher idle rpm. Mine is about 850 or so. I got to thinking (which is a dangerous thing for me) and I wondered if there is a way to keep the speed sensor on the transmission turned on and if so would that cause any problems? That sensor keeps the engine at about 1k if I am not mistaken
Ok -the smart guys if yall know a way please share.
olddragger
Old Feb 11, 2006 | 07:40 PM
brillo's Avatar
Go Texas Longhorns!
interesting, I'd love to increase it also to smooth out the idle.
I'm not aware of this sensor, when does it normally kick in?
Old Feb 12, 2006 | 09:11 AM
Rasputin's Avatar
How much you guys would you spend on an electronic device that would keep the engine idling at 1000 rpm (or any other idle speed of you choice)?
Fabrice
Old Feb 12, 2006 | 09:14 AM
rxeightr's Avatar
M0D Squad -charter member
Under $100 USD
Old Feb 12, 2006 | 11:11 AM
brillo's Avatar
Go Texas Longhorns!
Fabrice
if I could adjust idle speed at will, $300
Old Feb 12, 2006 | 12:09 PM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by Ryan13b
...I actually haven't noticed if there's a throttle cable or not, since the car is drive by wire, but if there is, you can usually tighten the cable just a bit.
Did you read what you just wrote?
Old Feb 12, 2006 | 12:40 PM
WantedTwo's Avatar
C4 burns real good
nice! I totaly missed that!
Old Feb 12, 2006 | 12:41 PM
olddragger's Avatar
Lol Yea Neb that sometimes reads like some of my posts before I reread them and edit.
Yea i would pay to get a device that would increase the idle I would want to be sure that it would not have any detrimental affect. Hook us up dude--everyone does know that this engine uses a lot more gas at 850k idle than a 1k idle
olddragger
Old Feb 12, 2006 | 04:45 PM
brillo's Avatar
Go Texas Longhorns!
the servo is all electric, so no luck there.
you could drill a hole in the throttle plate, which might work, but the PCM would likely throw a fit.
Old Feb 12, 2006 | 08:08 PM
Rasputin's Avatar
Won't work!
F
Old Feb 12, 2006 | 09:17 PM
brillo's Avatar
Go Texas Longhorns!
Won't work!
F
not trying to blow your trade secrets, but what are you thinking about doing?
Old Feb 13, 2006 | 02:54 AM
Rasputin's Avatar
I'll test my idea first. I've ordered some electronic parts today. Will test later.
Depending on demand and costs, I might just share it as an electronic DIY.
Also, I'm waiting to see whether an engine mount replacement solve the poor idle I'm experiencing on my car. I have the feeling, based on past experience, that the engine mount replacement, if applicable on my car, is not going to cure it completely.
However, I can tell what won't work and why :
- drilling a hole in the T/B plate : as it's the ETB that's also controlling idle, it will compensate (by closing half a degree or so) to obtain the idle speed that's has been calibrated in the PCM.
- mechanically blocking the pedal at a slightly higher position : firstl, good luck to achieve that. Secondly, by changing the Pedal Position Sensor position, you'l actually force the PCM strategy out of idle mode and into run mode. No more closed loop RPM-based idle control.
- mechanically blocking the T/B plate at a slightly more opened position : don't know what it wil do, but I guess the system won't like it. The DC motor might try to force it to close and burn or trigger a CEL or a default (limp home) mode. ETB limp home mode = T/B plate opened at neutral position (abou 7-14%), just enough to crawl off the motorway...
Any other idea?
Fabrice
Old Feb 13, 2006 | 04:36 AM
RX4life's Avatar
i really would love to raise the idle.. around 1K would be perfect..
Old Feb 13, 2006 | 04:51 AM
Rasputin's Avatar
Is that what you're ready to spend?
Fabrice
Old Feb 13, 2006 | 05:46 AM
StealthTL's Avatar
Metatron
Wink $99...
Fabrice is my hero!
Yes, I'm in if it costs less than $100, I love little "fooler" circuits!
S
Old Feb 13, 2006 | 08:53 PM
olddragger's Avatar
man--i hope this works out. It would be a good addition--I think a lot of people would like a slightly increased idle sppeed
olddragger
Old Feb 13, 2006 | 09:46 PM
yiksing's Avatar
the giant tastetickles
I think the idle speed was purposedly tuned that way to save fuel when idle, why mess with it unless you are experiencing near stalling.
Old Feb 13, 2006 | 10:12 PM
RX4life's Avatar
Fabrice
lol...yes if its deleivered with a european beauty...
Old Feb 13, 2006 | 10:13 PM
RX4life's Avatar
WRONG!
Old Feb 14, 2006 | 10:39 AM
olddragger's Avatar
car actually uses more gas at an idle speed befow 900 than at 1k--go figue
olddragger
Old Feb 14, 2006 | 05:51 PM
r0tor's Avatar
olddragger
did the car that happened to have this theory tested also have a lightened flywheel?
Old Feb 15, 2006 | 03:18 AM
Rasputin's Avatar
olddragger
Do you have data to substantiate this?
F
Old Feb 15, 2006 | 10:42 AM
olddragger's Avatar
I'll see if I can find the post I read concerning fuel use at idle--I think it was under a poor gas mileage one and a guy was talking about how he had to wait in traffic so much and was alarmed at how much gas the car was using during these waits. Someone else responded with the fuel useage of idle vs 1 1.5k and had the facts.
Increased idle speed to me is not about gas economy. Its about the car being much smoother. That was my oridginal point. The gas consumption was just a sideline discussion.
olddragger
Old Feb 15, 2006 | 10:48 AM
alcimedes's Avatar
The burninator
It would also be nice to keep the car from switching the firing order if nothing else.
Chalk me up as another person who'd pay $100 for a piece that would set the idle at 1k. (assuming it wasn't impossible to install)
Old Feb 15, 2006 | 04:40 PM
brillo's Avatar
Go Texas Longhorns!
if you want a idea of the market for a potential device that works, just do a seach under "idle"
you see all the rough idle threads and complaints.
