shifting check engine light problem
Old Feb 9, 2006 | 10:06 PM
fenderlover's Avatar
so in the past couple days my car has been flashing teh check engine light when i shift at high rpms
today i tested teh problem i waited until between 7 and 8 to shift to 2nd and 3rd then the light came on.
it wouldn't go away though
i turned off the car and turned it back on and it was still there
i wasn't redlining it. is this normal?
Old Feb 9, 2006 | 10:09 PM
flashing cel is a missfire. many reasons. hard light that wont go away is a stored code. see dealership.
Old Feb 10, 2006 | 09:27 AM
ya today its still on i'll call teh dealership today after school
Old Feb 10, 2006 | 11:45 AM
zoom44's Avatar
Originally Posted by fenderlover
is this normal?
you do understand that the whole point of a Check Engine Light is that the PCM has detected an ABnormal condition, right?
Old Feb 10, 2006 | 12:20 PM
ya but there are hundeds of things that can trigger teh light that aren't imidiate problems
Old Feb 10, 2006 | 01:54 PM
zoom44's Avatar
im just giving you a hard time you asked "is a CEL normal" which, of course, it isnt
Old Feb 10, 2006 | 05:38 PM
so today i checked my oil and it was dangerously low so i refilled it
should i run out so quickly. only has around 1500 miles on it
Old Feb 10, 2006 | 05:47 PM
Go48's Avatar
What do you mean by "dangerously low" and how much oil did you add? Oil consumption depends to some degree on driving style, but a qt. every 2,500-3,000 miles seems to be about average based on the member postings on this forum.
If you added a full qt. or more to bring the level to the top mark, you should check it frequently in the future to see if it is really using that much or perhaps it was not filled to the top mark the last time oil was changed.
Old Feb 11, 2006 | 01:54 AM
did the low oil light come on???? if not it was not low to the point of DANGER. btw you might want to read the owners manual. it is the glove box. lots of good stuff in it.
Old Feb 11, 2006 | 03:32 AM
kw1k's Avatar
yeah my Check engine was flashing alot when i went down to the malibu canyon run last month. But about 3-4 weeks later, I was doing donuts and the CEL was on Solid its bin about a week and it's still not going away? Is this going to be stored now to the ECU.
is my warrenty still safe?
Old Feb 11, 2006 | 07:10 AM
Go48's Avatar
Yeah, you're in real trouble now. The dealer will pull the CEL code which is probably the big brother donut CEL. Your warranty is toast.
Old Feb 11, 2006 | 12:52 PM
r0tor's Avatar
more proof they really are idiot lights...
Old Feb 11, 2006 | 04:16 PM
i called freeman mazda and schedueld to bring my car by. the CEL is still on though. i called friday so i think i should be ok warrenty wise
Old Feb 15, 2006 | 04:03 AM
kw1k's Avatar
what if i took it to be takin care of at my mechanic ? then their is no sign of a CEL
Old Feb 15, 2006 | 08:05 AM
Go48's Avatar
The DTC error codes will most likely be stored in ECU memory and the tech can retrieve them using their equipment.
Old Feb 16, 2006 | 02:08 AM
kw1k's Avatar
^ I'm thinking it might be my Intake. I'm probably going to put back my stock intake on, take it to the dealer i guess?
Also When i go to the canyons and im at high rpms, the CEL light will start to flash on & off , goes away for like 6-7 secs then comes back on either flashing or stays on.
BTW, Whats a DTC code?
Old Feb 16, 2006 | 06:18 AM
Go48's Avatar
Diagnostic Trouble Code.
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
