Wheels help!!
Old Feb 7, 2006 | 04:41 PM
Terrance26's Avatar
8 all the way
Wheels help!!
I am in the process of purchasing some wheels but I just have a single question? The wheels that I want comes is size 20, they have 2 sets of the same wheel posted 1 set of wheels is et 42 and the other set is et 45. Which set do I get the 42 or the 45, and what does that mean?
Old Feb 7, 2006 | 04:54 PM
BlueEyes's Avatar
Might want to post this in the wheel section.
And, how many necklaces do you have on right now?
Old Feb 7, 2006 | 05:37 PM
delrmx01's Avatar
Old Feb 7, 2006 | 08:25 PM
Terrance26's Avatar
8 all the way
You must be a very lonely person. Anyway does anybody know what the et means?
Old Feb 7, 2006 | 08:31 PM
XeRo's Avatar
Normality is Obscene
you sure you don't want the 22x6.5, i mean..everything is BIGGER in TX right, Why not go all out? Those would fit great...make sure you get the spinners also...its not complete with out those...if you half *** it...you won't get any luv here yo..
Old Feb 7, 2006 | 08:32 PM
BlueRenesis82's Avatar
Registered Tracker
e/t is elapsed time. Commonly used for timing 1/4 mile races
Old Feb 7, 2006 | 08:39 PM
BlueEyes's Avatar
Yeah, I am. Very lonely, and cold. However, I now know what the ET of a wheel means, and that should keep me warm a night. HINT: I found out by using google.
Old Feb 7, 2006 | 08:40 PM
lazi's Avatar
drivelinestore.com
20X7.5? are you kidding me? shoot me now. please
Old Feb 7, 2006 | 08:50 PM
Terrance26's Avatar
8 all the way
Why are you hating on texas?
Old Feb 7, 2006 | 10:27 PM
BigOLundh's Avatar
#1 Legend
Texas rules
and et is referring to the offset.
42 and 45 are very odd offsets. Interesting how they made two molds and sets of wheels that have an offset of just 3mm apart. Anyway, how wide are the wheels? Until you know the width of the wheel... its not possible to calculate how it will fit on your car.
I'm not a fan of 20" rims, but i also don't care. If thats what you want... we'll try to help you find a set that fits.
-hS
Old Feb 7, 2006 | 10:28 PM
BlueEyes's Avatar
He originally said the size was 20x7.5, now it just says 20.
Old Feb 7, 2006 | 10:35 PM
BigOLundh's Avatar
#1 Legend
If its 7.5 he needs a lower offset. 42 might work.
Its 8mm further out than stock, but the wheel is .5" narrower, and hence .25" (6.35mm) closer to the caliper. So essentially with a 42mm offset he'll be 1.65mm further away from the caliper.
That is cutting it really close. If the spokes on these rims are thicker than stock... you might have issues with it hitting the caliper.
Do they come in a lower offset?
-hS
Old Feb 8, 2006 | 11:33 AM
XeRo's Avatar
i'm not hating on TX...did i say i hate TX...um nope...
Old Feb 8, 2006 | 11:35 AM
XeRo's Avatar
-hS
we sure as hell will..and make lot's of fun of you while we're at it...that's how this place runs...heck..i even make fun of myself sometimes....you gotta relax there buddy...
Old Feb 8, 2006 | 03:26 PM
No, no no! You cannot tell caliper clearance based on offset or any other general dimension when discussing a different/unknown wheel. It depends on how the spokes curve and they don't give dimensions on those.
Also, offset is based off the centerline, so width has no bearing on it. The change is the difference between the offsets; 50mm - 42mm = 8mm. The wheel lip positions change based on the difference in width and offset relocation.
8 - 7.5 = 0.5" width change but you have to divide by 2 to get the change per lip = 0.25"
the ouboard lip moves in 1/4" from the width change and then out 8mm from the offset change, so the outboard wheel lip is 1.65mm further outboard than the OE wheel lip position
the inboard lip moves toward the outside 1/4" due to the width change and out another 8mm due to the offset change, so the inboard lip moved 14.35mm toward the outside relative to the OE wheel lip position
Old Feb 8, 2006 | 07:36 PM
BigOLundh's Avatar
#1 Legend
I think if you know the offset and width you know how much further away from the caliper you were going to be. True, you won't know exactly because alot of it depends on the design of the spokes. But i knew on my wheels that going to a 9.5" width rim and -10mm in offset, was going to push me out ALOT further than stock... so brake caliper wasn't a huge concern of mine.
I'm not telling Terrance his won't fit... but he is running really close, and should be cautious.
-hS
Old Feb 8, 2006 | 08:06 PM
Terrance26's Avatar
8 all the way
I ordered the wheels with the et of 42 because thats what the retailer recommended. The size of the rim is 20x7.5, now I am looking for tire size that would be the best fit and look for that size rim. Any suggestions?
Old Feb 8, 2006 | 09:16 PM
Terrance26's Avatar
8 all the way
Anybody?
Old Feb 8, 2006 | 10:28 PM
BigOLundh's Avatar
#1 Legend
I wouldn't suggest going wider than 225.
Old Feb 9, 2006 | 07:42 AM
Terrance26's Avatar
8 all the way
why? I have no clue about tire sizes.
Old Feb 9, 2006 | 07:51 AM
Terrance26's Avatar
8 all the way
now is 225 30 20 a good size tire for the rim?
Old Feb 9, 2006 | 01:10 PM
XeRo's Avatar
wait a minute...for real though no joke...why did you pick to go with 20x7.5 that will almost look like an old 1800's wagon wheel...find some pics of KelRX8's ride...he has 20's and probably the most perfect fitment of them...if i can find a link to his i'll post it up later...i think you'll be dissappointed with 7.5..
Old Feb 9, 2006 | 05:44 PM
BigOLundh's Avatar
#1 Legend
Stock OEM 8" wide rim can fit up to 245, but no more.
If its 7.5" 225 should be good... maybe 235.
the 225-30-20 size should be ok.
-hS
Old Feb 9, 2006 | 09:34 PM
-hS
I'm not saying that either, I'm just saying that you can't tell one way or another just by the specs. Somebody has to have verified it otherwise you're shooting in the dark. In this case the supplier recommended it, so it's probably safe to say that it's been checked and known to work. Further, it may clear now, but have issues with other subsequent mods. As an example, the OE 18" wheel has plenty of clearance with the RacingBrake BBK, but we discovered that the Enkei RPF1 18 x 9.5 x 45mm offset sold by Goodwin Racing needed a 5/16 spacer to clear the caliper. The spokes on the Enkei wheel curved in a lot sooner than the OE wheel, there's no way to know that from the specs. RacingBrake is in the process of relocating the caliper and rotor to provide clearance with the Enkei so it will be a non-issue soon.
Old Mar 2, 2006 | 10:52 PM
Terrance26's Avatar
8 all the way
Why would it look any thinner than the stock tires. The stock tires are 225, and that is the same size I am going with with the 20s.
