What effect dose this have on MPG?
Old Feb 6, 2006 | 01:14 PM
Raptor75's Avatar
Can anyone tell me what this device will do to my mpg?
Old Feb 6, 2006 | 01:47 PM
expo1's Avatar
He's as bad as Can
Since there is no device in your post it will be hard to answer.
You can either edit your post to add a link to said device or a photo of it.
You can delete your post, which will make this all go away and start over.
You can delete your post and forget about the subject, as there is no aftermarket device that can improve MPG much. Some people have reported a slight improvement with the Revi Intake by RacingBeat. But at $350 the break-even point is far away.
Old Feb 6, 2006 | 02:25 PM
khtm's Avatar
I like rusty spoons
I'd say creating a new thread that makes no sense at all will probably reduce your average MPG by 1-2.
Old Feb 6, 2006 | 03:33 PM
rabinabo's Avatar
I'm assuming that since he posted in the Greddy eManage forum that he meant the Greddy eManage.
Old Feb 6, 2006 | 03:54 PM
expo1's Avatar
He's as bad as Can
Damm that sure makes sense (note to self read name of forums threads are posted in ).
To Raptor75 I know of no member using the Greddy Emanage on a Non-Turbo charged car. You would be the first, this device would let you change the air fuel ratios of the car and in theory you could run on less fuel. Now how would you know what changes to make ?????? Well someone has to be the first, there are also dire risks to being wrong. You would also void your drive train warranty if the dealer saw it and the cost of the necessary hardware, cables etc would make the break-even point further and further away.
Old Feb 6, 2006 | 04:18 PM
zoom44's Avatar
MM was using the emanage long before he put his turbo in. everyone that used a canzoomer was using an emanage.
Old Feb 6, 2006 | 05:44 PM
r0tor's Avatar
how many times can someone get pw3ned in a thread while not obviously trolling
if you see a gas milage effect it will be in the positive direction. Since little is done in the way of fuel adjustments below 5500 rpms, you may or may not benefit depending on your driving style.
WranglerFan
Aug 21, 2022 01:29 PM
drebbrnator
Dec 27, 2018 07:02 PM
GranTouTou
Sep 30, 2015 06:11 AM
yapakanichi
11
Sep 23, 2015 02:14 PM
CMRine04
Jul 29, 2015 02:07 PM
