Oil Level
Old Feb 5, 2006 | 05:57 AM
AC_SB's Avatar
Oil Level
Hey guys, just a quick question here....Since I got my 8, I've put on roughly 1500kms....at what point should I check the oil? I've heard its around the 3000km mark...is that accurate or is it on a car by car basis?
Thanks in advance
Old Feb 5, 2006 | 06:04 AM
yiksing's Avatar
the giant tastetickles
Since its new, it will consume more oil. After a while the consumption will be more or less consistent, until then check it regularly. I do it every full tank at first, now I could leave it for 2 to 3 full tank unless you always pull to redline (more consumption). Next time use the SEARCH button.
Old Feb 5, 2006 | 06:52 AM
StealthTL's Avatar
Metatron
Wink Advice?
Do you really need a consensus of the opinions of other owners before can you lift the hood and pull the dipstick?
How about you just look, see where it's at?
S
Old Feb 5, 2006 | 10:51 AM
9291150's Avatar
Every second gas fill-up.
And try to ignore the smartasses like StealthTL.
Old Feb 5, 2006 | 11:48 AM
Gord96BRG's Avatar
Disagree - ignore StealthTL at your peril, he is one of the earliest RX-8 owners, and has extensive knowledge and history with the RX-8.
See, that question begs for a smartass answer! However...
Where did you hear it's around 3000 km to CHECK the oil? Honestly, you should try reading your owners manual, cover to cover. It recommends checking the oil at EVERY fill-up. Every second, at least. While the actual oil usage might be a litre every 3000 km approximately, it's NOT exact, and can vary depending on conditions and how you drive over the interval.
CHECK every fillup or two.
ADD when the oil level gets near the fill mark, whick will likely be after 2000 - 3000 kms.
Regards,
Gordon
Old Feb 8, 2006 | 11:48 AM
Admiral8's Avatar
Speaking of checking the oil.
Does anyone else find the dipstick for this car to be useless?
It's very hard to read the oil level on it because it is so poorly marked.
Old Feb 8, 2006 | 05:25 PM
Hellbreed's Avatar
yes it sucks, especially in the winter when the milkshakes start to happen. There is a new dipstick for the RX-8 with better markings but not sure how much they are. It's in the technical bulletin but I don't remember if it's changeable under warranty for anything, never looked into it.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
yankeepicker
Sep 11, 2015 05:42 PM
