View Full Version : Tranny and Diff Fluid swap: Gotta take it to a mechanic
Big_Mike_4488 02-04-2006, 09:38 PM Well, I've read all the DIY's on this topic, but the final verdict is that I don't have the means to elevate the car, as I have no floor jack or jack stands. I'm gonna take it to the same guy that me and my dad have been goin to for a few years now, but I have a few questions, as I have never had to have Trans. or Diff fluid changed before. I am going to put Royal Purple fluids in it, so I already know I'm going to have to bring my own fluids. My first question is, am I going to have to bring my own crush washers for him to put in during the change? Is changing out these washers standard procedure on most cars? Also, is the fluid changes for the Rx8 pretty similar to most other cars, or am I going to have to explain to the guy some of the differences between this car and others. He really knows what he's doing, and he's been around a while, but I just didnt know if this aspect of the 8 was as mysterious as some of the other aspects of the car.
EDIT: Any advantages to using Redline over Royal Purple or are they about the same??
Gomez 02-04-2006, 10:32 PM Don't bother with new washers, most dealers won't have them anyway. The old ones are fine for reuse. Both those oils are good.
Nothing weird for your mechanic to worry about. The changes here are standard fare.
Big_Mike_4488 02-05-2006, 11:58 AM Thank you. I think I might actually end up going with Redline. Just hope the labor isnt too much considering I could have done this myself had I had the means of lifting the car.
brillo 02-05-2006, 12:27 PM I've used both, I prefer RP, but thats mainly cuz is a Houston Company
rabinabo 02-05-2006, 01:23 PM Why don't you just buy a jack and jack stands? They're not that expensive, and you never know when you'll need it.
Big_Mike_4488 02-05-2006, 01:43 PM Why don't you just buy a jack and jack stands? They're not that expensive, and you never know when you'll need it.
True, I had thought about it. But I figure that I wont have to get the Tranny and Diff. fluids changed again for a while. I would rotate my own tires, but my dealer still does it for free under warranty. Anything else that required the complete lifting of the car, I probably wouldnt have enough automotive knowledge to work on it anyway.
rabinabo 02-05-2006, 11:08 PM Yeah, you're probably right, you won't need a jack for much else then. I just think that in most places you'll probably pay much more for the tranny/diff fluid swap than for a cheap set of jack/stands. I paid around $20 at walmart a few years ago for a jack/stands/lug wrench/car blocks during a thanksgiving day sale, and I still have them. You can easily pay that much for an oil change.
Actually, the only reason I'd be inclined to not buy one just in case is to not have another thing (and a heavy one at that) clogging up my closet.
Big_Mike_4488 02-06-2006, 12:56 PM I dont think I would trust my life to a cheap set of jack stands though. No judgements on yours, as I don't know what kind you have, but just a general statement.
Jaguar_MBA 02-06-2006, 01:03 PM I don't have the means to elevate the car, as I have no floor jack or jack stands.
?? :Eyecrazy: The car comes with a scissor jack. Use that to jack the vehicle up and slide some large blocks of wood under it. Done.
rabinabo 02-06-2006, 03:45 PM These stands I have came from a fairly reputable brand. It's not like it's that difficult to make, really, it's just cast steel with a locking mechanism. If somebody makes them out of their garage, then I'd definitely have second thoughts.
Now I probably won't use my jack anymore actually, since I have access to a full garage with lifts, etc.
BaronVonBigmeat 02-06-2006, 03:54 PM Once you see the price of labor, you may think twice about doing it yourself. I just used a pair of ramps, that worked fine. The actual job could be done by a child, just make sure you have the right sockets (one of them on the diff is an oddball size IIRC) beforehand, and a little fluid pump too.
There's only 2 bigass bolts on the driver's side of the transmission. Bottom one drains, top one fills. Drain it, and then fill with the pump until it's spilling out the top hole, then cap it off with the plug. Repeat for the differential. It's even easier than an oil change, because you can't overfill it.
Big_Mike_4488 02-06-2006, 08:33 PM I just used a pair of ramps, that worked fine. .
I was under the impression that the car had to be perfectly level. If ramps is all I need, I would be fine to do it myself, but from what I've heard you have to lift the whole car.
It's important to have it level so that you get the proper amount of lube back in the case. The procedure is to add until it starts leaking out the fill hole. If it's not level that could result in too much or not enough. If you lucky enough to have the right kind of sloping driveway using ramps can work or you can use ramps on one end and jack/jackstands on the other.
Using a scissors jack to hoist all 4 corners onto stands and back down is a real pain. A low-profile hydraulic floor jack is a very nice convenience.
I wouldn't expect the mechanic to charge an arm and a leg. It's not much different than an oil change and there's no pesky filter to deal with. With the car on a lift and proper pumps for the oils I think it'd be a breeze.
The one nice thing about DIY is you can make absolutely sure you're putting the right lube in the right case. It's not like getting 5w30 instead of 5w20 in the crankcase. Getting GL4 and GL5 mixed up can be VERY BAD.
carbonRX8 02-07-2006, 08:41 AM ?? :Eyecrazy: The car comes with a scissor jack. Use that to jack the vehicle (#) up and slide some large blocks of wood under it. Done.Yeah, then crawl under your car and enjoy what Dark Age torturers called "Peine forte et dure ." It is quite the thing. Just ask the witch Giles Corey. He enjoyed it so much he asked for more!
Big_Mike_4488 02-07-2006, 03:54 PM Well, I talked to the guy today. The labor isn't gonna be too bad, but he called his friend at the Mazda dealership, and called me later that day to tell me the Mazda people said putting synthetic tranny and diff. fluid in the car is quote: "a very bad idea". I knew this was the case with motor oil, but was surprised to hear this about the fluids. I know a lot of you have made the swap. Anyone else got some info. on this claim?? I hope Mazda isnt just saying this for no reason.
StealthTL 02-07-2006, 04:17 PM You are confused - that wasn't "Mazda" talking, it was some dickhead at a dealership; definitely not the same thing!
The dealer saying "it's a terrible idea" only means they don't have any synthetic, nothing more!
They don't get much call for it, and make much more profit if you would just take the stuff they got in "the drum" back there.
Take it to a local independant garage, the mechanic will respect you and your choice.
S
mikeschaefer 02-07-2006, 08:42 PM I've read about dealerships that actually say it is good thing to swap in synthetic. Some say otherwise. Mine said it would void my warranty if I did!
Big_Mike_4488 02-07-2006, 09:20 PM Void your warranty? Wow. I thought they had to prove that it actually caused a problem in the car in order to void the warranty. What exactly do the Mazda guys say can go wrong by adding synthetic tranny and diff. fluids??
Gomez 02-07-2006, 10:19 PM They won't even know you've put it in there.
TeamRX8 02-08-2006, 07:49 AM I swear, dealerships must hire people with a college degree in stupidity
Big_Mike_4488 02-08-2006, 09:38 AM Well, I just talked to the head guy at my local Mazda's service department. He said Mazda has not said yes or no as far as synthetic fluids, but that it is perfectly safe for the car. Quite a difference since yesterday when some other fella tells my mechanic that using synthetic is a "very bad idea". Oh well, time to order the fluids. Thanks for the help everyone.
EDIT: One last question. I went to the Rosenthal Mazda website to order the fluids and the washers. It only had the drain plug washers for the tranny and diff. Do I need to switch out the fill plug washers too? If so, are they the same as the drain plug washers??
Ok, EDIT #2: Called my mechanic back. (The one who talked to the stupid mazda guy yesterday) Anyway, he is very hesitant about doing the process, since the guy told him Mazda said not to. He also told me that the Mazda guy said something about having to add an extra additive from Mazda for the differential fluid because it is a limited slip? WTF? I've never heard anyone mention this before, and I'm hoping this isnt the case. Anyway, he gave me a $120 quote for just labor, so I think I will be shopping around for someone else to do it, or might even spring for buying floor jacks and jack stand.
Chamberlin 09-01-2006, 12:12 PM as a followup, some of the RP (and others) gear fluids already have the additives for the LSD built in... but I think it only matters if you have friction plate style LSD, not gear type LSD's?
-C
mysql101 09-01-2006, 12:37 PM Get royal purple.
I had both redline and royal purple in my car, and both function similar. I noticed rp worked better when cold, and the car shifted normally with it, vs a notchy feel with redline before it was warmed up.
mac11 09-01-2006, 01:51 PM This doesnt seem like it should be that big a deal.
Buy the fluid of your choice(redline, royal purple, AmsOil....etc), buy a jack and jack stands, buy the proper sockets and a ratchet, i suggest a 1/2" drive set or at the very least a long handled 3/8" drive set(just personal preference) and a pump. All things should be had for under $100. And yes the cheap wal-mart kind are fine. You can also get a craftsman set from sears for like $40 or so. and go to town. its really rather simple. I would also suggest a small bag of oil dry, kitty litter, or sometimes a hardware store will give you a bag or saw dust they are going to throw out for free for the fluids you are going to drip on your garage floor. and have fun. Its not like you are trying to pull a drivetrain out of a car from a muddy junkyard in the rain here or anything.
CarAndDriver 09-01-2006, 02:08 PM From what I have read on here and from people's results, RP is the way to go for transmission and differential. Max-Gear 75W90
http://www.royalpurple.com/prodsa/mgeara.html
mac11 09-01-2006, 02:26 PM From what I have read on here and from people's results, RP is the way to go for transmission and differential. Max-Gear 75W90
im a n00b here, are you really with car and driver? or are you just a smartass? :Peace:
CarAndDriver 09-01-2006, 02:40 PM im a n00b here, are you really with car and driver? or are you just a smartass? :Peace:
A smartass made smarter by reading this board. :yesnod:
CarAndDriver 09-01-2006, 02:42 PM Ok, EDIT #2: Called my mechanic back. (The one who talked to the stupid mazda guy yesterday) Anyway, he is very hesitant about doing the process, since the guy told him Mazda said not to. He also told me that the Mazda guy said something about having to add an extra additive from Mazda for the differential fluid because it is a limited slip? WTF? I've never heard anyone mention this before, and I'm hoping this isnt the case. Anyway, he gave me a $120 quote for just labor, so I think I will be shopping around for someone else to do it, or might even spring for buying floor jacks and jack stand.
I was recommended to an independent Mazda mechanic in my area and he quoted me $75 labor + $6 hazardous disposal fee.
nycgps 09-05-2006, 01:43 PM Well, I talked to the guy today. The labor isn't gonna be too bad, but he called his friend at the Mazda dealership, and called me later that day to tell me the Mazda people said putting synthetic tranny and diff. fluid in the car is quote: "a very bad idea". I knew this was the case with motor oil, but was surprised to hear this about the fluids. I know a lot of you have made the swap. Anyone else got some info. on this claim?? I hope Mazda isnt just saying this for no reason.
Please Tell your mech's friend's boss to fired your mech's friend.
I understand the agurment between synthentic and Mineral, but thats for engine oil.
Trans and rear diff ? WTF ?
mac11 09-05-2006, 01:47 PM Please Tell your mech's friend's boss to fired your mech's friend.
you are not intelligent.
nycgps 09-05-2006, 01:49 PM you are not intelligent.
I never said Im
but I think u're dumber than me.
http://img359.imageshack.us/img359/3761/dumb20and20dumbererp7kd8ph0.jpg
mac11 09-05-2006, 04:08 PM I never said Im
based on what?
I'm not the one that thinks that there is no possible way a tranny and/or diff could possibly have an actual oil specification.
'Na just go ahead and dump anything in there'
nycgps 09-05-2006, 09:31 PM oh yes, you can dump anything in there, as long as its within the "SPEC".
I never said u can dump canola in there, lets see whos the dumbass now ?
Same thing goes for Engine oil. Babies cry when they see synthentic, the sad thing is that Im using it, and I have no PROBLEMS ! and guess what, my Synthentic oil is WITHIN THE SPEC !
Get a life, moron.
mac11 09-05-2006, 09:41 PM i never said synthetic couldnt be used did i?
i believe what i said was: there may, just possibly, be an actual requirement that needs to be met in the type of fluid used.
Punksux 09-05-2006, 10:56 PM Well, I just talked to the head guy at my local Mazda's service department. He said Mazda has not said yes or no as far as synthetic fluids, but that it is perfectly safe for the car. Quite a difference since yesterday when some other fella tells my mechanic that using synthetic is a "very bad idea". Oh well, time to order the fluids. Thanks for the help everyone.
i did my change of tranny and diff fluid at a mazda dealership in albany and it cost me 80$ total. 40 for the tranny and 40 for the diff. I supplied them with the redline fluids. I am guessing the 120 is the normal price they usually give to people for the labor plus oil. I was quoted a similar amount at a jiffy lube place. Something about them not being able to change the price even if i provided fluid which is horse crap.
zenmoused 09-05-2006, 11:39 PM Yeah, good work on avoiding jiffy lube. As they say in Spanish, "el bad-o."
staticlag 09-05-2006, 11:50 PM Swapping the tranny fluid is super easy, the only bolt you need to take off under the car is the drain bolt, and then just pour 2 quarts in though the shifter hole.
CarAndDriver 09-05-2006, 11:53 PM i did my change of tranny and diff fluid at a mazda dealership in albany and it cost me 80$ total. 40 for the tranny and 40 for the diff. I supplied them with the redline fluids. I am guessing the 120 is the normal price they usually give to people for the labor plus oil. I was quoted a similar amount at a jiffy lube place. Something about them not being able to change the price even if i provided fluid which is horse crap.
I'll probably get quotes from my two local dealers as well.
juikster 09-06-2006, 08:38 AM I had mine changed by a neighbor who thinks if he doesn't use his crafsman ramps and 3 ton craftsman jack everyday, life as we know it will come to an abrupt and crazy end...so to not spoil his graditude of job well done, I provide the beers.....He's a saint... :D:
nycgps 09-06-2006, 08:43 AM i never said synthetic couldnt be used did i?
Uhh huh, maybe its time for you to learn how to read.
theres no "ifs/maybe". Its all in the manual.
Better luck next time, smart one.
zenmoused 09-06-2006, 03:46 PM I guess it's whatever floats your boat. I for one happen to enjoy spending time working on my car. Some people would rather be doing something else. The procedure takes all of half an hour (an hour if you are meticulous about it), and requires very minimal supplies. Who knows, if you get jack stands, maybe you'll be inspired to start tearing more things apart on your 8 ;-)
CarAndDriver 09-08-2006, 12:01 AM After reading threads on here and the RX-7 board, I went with RP. Redline seems to be notchy until warmed up.
I bought 4 qts for RP Max Gear for $8.99 a bottle with free shipping from this place. http://www.mustangtuning.com/royal-purple-max-gear-75w90-gear-oil.html
KJ238 09-08-2006, 12:32 AM Using RP here.. Pretty good...
mac11 09-08-2006, 09:07 AM Just a question...why is AMSOIL never brought up in this community when synthectics are being discussed.
I personally will never switch unless I get a car that has some confliction with AMS.
Red Devil 09-08-2006, 09:23 AM Just a question...why is AMSOIL never brought up in this community when synthectics are being discussed.
A lot of the Aussies seem to like Amsoil, as I recall. It does appear that State-side, Royal Purple (probably because of Racing Beat) and Redline get most of the attention.
BlueRenesis82 09-09-2006, 08:25 AM +1 for synthetic gear and diff fluid. That was the second thing I did with my car, had 5k miles on the OEM fluids. Much smoother feel and I know they can take a little more hard driving
bsteimel 11-24-2006, 08:24 PM I realize most people either use RP or redline, but what kind of oil do people use specifically. Our manual trans takes gl4 or gl5 and our diff takes gl5, both with 75W-90.
Do people use the gl5 or the gl4 in the transmission?
do we need hypoid friction modifiers?
Would these be the best for RP and Redline?
RP:
diff: max gear 75W-90
trans: Synchromax 75W-90
or is it max gear for both the trans and dif?
Redline
diff: 75w-90 gear oil or 75-90 NS?
trans: MT-90 or 75W90 NS?
sorry i reposted this question to this thread thought the heading was more appropriate
http://www.rx8club.com/showthread.php?p=1627544&posted=1#post1627544
