Collings
02-03-2006, 07:44 PM
Hey, all. I have two problems with my transmission. I'm taking the car to the dealer on Monday, so I thought I would ping the community and see if anyone else has a similar experience.
Originally it was very difficult to engage 5th and 6th gears. I would put firm pressure on the stick and hold it in place, and it would take a long time before the transmission would finally go into gear... At least two or three seconds. My salesman told me it would loosen up over the break in period, and it actually has gotten a little bit easier.
But on to the immediate problems:
First: My '05 has about 3000 miles on it now. Ever since I picked up the car, the transmission has made a LOT of noise when idling in neutral with the clutch out when the car is stopped. When I put the clutch in, I can hear the transmission sort of grind to a stop. The car is like 5 times louder when the clutch is out then it is when the clutch is in at a stop.. When you put your clutch in at a stop, do you hear a big change in your transmission's sound?
When I installed my iPod adapter, I drove the car with the plastic trim piece around the base of the shifter off to the hardware store and back, and my transmission sounded like mechanical gear-lashing death down there. My last few cars have been either front wheel drive or mid engine, so I've never sat so close to the transmission that I could hear it before.. Or is it that Honda and Toyota transmissions don't sound this awful? I've never been so careful with a car because I'm terrified it's going to break all the time!
When I installed my iPod adapter, I drove the car with the plastic trim piece around the base of the shifter off, and my transmission sounded like death down there. My last cars have been either front or mid engine, so I've never sat so close to the transmission that I could hear it before.. Or is it that Honda and Toyota transmissions don't sound this awful?
Second: A few times in the last few days when shifting from 4th to 5th, I'll push the stick towards 5th, but it's like pushing it against a wall. There's simply no 5th gear there, and I can hold the stick there as long as I want without feeling a change. I will shift back into 4th, then into 5th again, and it will engage normally. Anyone experienced this?
Third: I've noticed a few times that when I'm backing up in reverse and I put the clutch in, there's a LOUD lashing release.. I imagine it sounds like the drive-train is bound up, and when I push in the clutch a bunch of tension is being released. I can feel it shudder through the car when it happens. I heard this happen when a salesman was backing up in another one of the '05 cars that I test drove before buying mine, so maybe it's endemic to the car somehow.. Have you heard this?
Thanks,
Collings
Thanks,
Collings
