Developed Backfires
Old Feb 3, 2006 | 03:13 PM
mike1324a's Avatar
Need'd a Turbo
Developed Backfires
I got my oil changed at 10,000 miles. Prior to that oil change i was using Castrol GTX, but at 10,000 miles i put Mobil 1 in it. Now when i step on the gas hard(not noticed it moving only because its quiet) it backfires alot. Its not loud. It actully sounds like a puffing sound. Any thaughts on the issue?
Old Feb 3, 2006 | 03:29 PM
zoom44's Avatar
plugs are fouled not geting a hot enough spark to ignite all the fuel. unburnt fuel in the exhaust burning off
Old Feb 3, 2006 | 03:32 PM
mike1324a's Avatar
Need'd a Turbo
remedy?
Old Feb 3, 2006 | 03:40 PM
zoom44's Avatar
clean the plugs
Old Feb 3, 2006 | 03:51 PM
ZoomZoomH's Avatar
Mulligan User
would said fouled plugs be related to Mobil 1 oil?
Old Feb 3, 2006 | 04:03 PM
zoom44's Avatar
i did not say it has anything to do with the type of oil. he has backfiring which means rich . its not the normal richness of the car since he didnt have it before. one reason for richness could be fouled plugs. since its relatively easy to pull and clean plugs he might as well start there.
Old Feb 3, 2006 | 04:10 PM
mike1324a's Avatar
Need'd a Turbo
Ok that sounds like a good idea. I was afraid you ment the plugs need replacing.
Old Feb 4, 2006 | 05:48 AM
WantedTwo's Avatar
C4 burns real good
I remember reading a post from RG about this, sail mobil 1 was bad for a rotary.....
Old Feb 4, 2006 | 07:41 AM
Go48's Avatar
Unless you have the proper tools--like the sandblaster thingy--for cleaning the plugs, you may, indeed, have to replace them. The key thing is to get the center insulator clean and sandblasting is the best way to do that.
TeslaMSI
Dec 10, 2015 01:10 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
