Royal purple reccomendations
Old Jan 26, 2006 | 08:07 PM
Moonrover333's Avatar
My Goodness My Guinness
i'm planning on doing the MT gear oil soon along with the rear end. i think i'm gonna go with royal purple since i've heard its a good all around formula for cold/ hot weather.
what weight should i go with and also are there any other brands i should go with instead: Mobil, redline, motul etc?
any help is good
also i tried search but didn't really know what to put in box so i kinda gave up quick you can just link if you want
thanx in advance all
Old Jan 27, 2006 | 08:02 AM
Bloodroz's Avatar
I switched to all royal purple fluids in my 8 and it worked out nicely... A little costly about $90 for all the fluids including the radiator fluid addative which actually NOTICABLY lowered my engine temps.... For the motor oil 5-30 and the others i cant remember ill look and check for you and see if i can find it on the net
*Edit
synchromax for the transmission just make sure you get the one for manual not auto
Max-Gear for the rear end (weight unknown i think it was 75 but dont quote me on that)
Purple Ice radiator addative
Old Jan 27, 2006 | 11:01 AM
rotarygod's Avatar
75W90 for the rear end.
Old Jan 27, 2006 | 11:32 AM
Red Devil's Avatar
I'd heard in the past from a very reputable rotary tuner that using anything like Redline Watter Wetter or Royal Purple's Ice additive was very bad for rotaries. That the coolant was getting into the engines and the additives were causing a lot of damage.
Anyone care to confirm or refute this claim? From that recommendation I've always stayed away from such products.
Old Jan 27, 2006 | 11:47 AM
rotarygod's Avatar
There is nothing different material wise in a rotary than there is in any other engine.
Old Jan 27, 2006 | 11:53 AM
Red Devil's Avatar
I'm recalling what I was told from years ago: but weren't the older rotaries injecting a small amount of coolant would be into the housings at start-up, or something like that? And it was then that allegedly the additives were prematurely wearing the seals.
I don't know, I always was confused and thought was you just said RG...
Old Jan 27, 2006 | 12:10 PM
rotarygod's Avatar
The RX-7's had something called sub zero starting which would inject a small amount of coolant into the combustion chamber from a separate reservoir when the temperature dropped below freezing. It wasn't much, just a few drops. Not enough to matter. There's no worry with using those coolant additives.
Old Jan 27, 2006 | 12:20 PM
Purple Ice radiator addative[/B]
Can't you put Max Gear 75/90 in the tranny?
From Royal Purple's website:
Synthetic Gear Oil» Max-Gear® is formulated to improve the efficiency of rear end assemblies and manual transmissions. Virtually eliminates both gear and bearing wear. API GL-4 / GL-5 Certified.
Old Jan 27, 2006 | 12:55 PM
rotarygod's Avatar
Max Gear 75W90 is what I use in both the tranny and rear end.
Old Jan 27, 2006 | 12:59 PM
Thanks RG, gave me a scare the for a second considering I just put Max Gear 75/90 in mine a few weeks ago.
Thanks,
Old Jan 27, 2006 | 01:18 PM
Red Devil's Avatar
Yeah, I've had 75w90 Royal Purple in both my tranny and differential for the last 10k.
Old Jan 27, 2006 | 01:45 PM
dgcls's Avatar
can someone specify how many of the 75/90 oils are needed to fill both gear & rear... thanx
Old Jan 27, 2006 | 03:00 PM
Red Devil's Avatar
I want to say it was like 2.5 quarts total, or somwhere around that.
There is a DIY in that section of the forum on this very subject. The amounts needed are listed in that thread.
Old Jan 27, 2006 | 03:31 PM
I bought 4 Max Gear 75/90 and it seemed to do that trick.
Old Jan 27, 2006 | 04:07 PM
KWS's Avatar
KWS
Synchomax is the wrong stuff for the RX8 transmission. This came up once before so I checked back with Royal Purple and here is their response:
Your friend is incorrect - the transmission should use our RP MaxGear 75W90.
That's what I have in my 94 R1 RX7.
Cheers,
David
David Canitz
Tech Services Manager
Royal Purple Ltd
1 Royal Purple Lane
Porter, TX 77365
281-354-8600 x202
281-354-7335 fax
713-725-7207 cell
dcanitz@royalpurple.com
Old Jan 27, 2006 | 04:14 PM
Red Devil's Avatar
Doesn't get better than that when the guy responding has an RX vehicle.
As a side, I think by '94 they'd changed it to the R2 package and the R1 was only for the '93 model.
RAE008
Sep 12, 2015 09:08 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
rotarygod
66
Sep 27, 2004 12:46 AM
mike_rx8
Jun 4, 2004 01:24 PM
