Hardwiring Radar Detector...???
Old Jan 26, 2006 | 06:08 PM
PIGBAIT's Avatar
Hey guys.....I have a gift certificate to Sharper Image that I've had for a year and I want to get rid of it. So I was thinking about buying a radar detector, the Passport X50 to be more specific. I live in the Pacific Northwest if that matters....
Now I have absolutely no clue about radar detectors, never had one, never seen one used. Don't even know for sure exactly what they do Ugh, i'm an idiot.
Is there a guide for dummies for radar detectors or something? Anyway, I've never purchased one because I hate that damn power cord. But I have the homelink unit on my rear view mirror so I figure I can hardwire to that. Is this something a stereo installation place would do for me? How much would it cost?
If this has been covered before (im sure it has) I'm sorry. I tried searching but there was a ton of **** and I'm at work so I cant be screwing around searching for posts all day
Thanks guys!
Old Jan 27, 2006 | 05:56 AM
jskup1's Avatar
The Chief
I don't know if you really want to go tapping into your mirror or not. An easy way to do it would be to run the wire around the windshield and under the dash and ashtray. Cut the plug off of the radar detector. There should be two wires. Strip the insulation off of the striped one and tap into the yellow wire of the cigarette lighter and then strip and ground the other. Another advantage of this set up is that when the car is off, your radar detector will be off as well.
Old Jan 27, 2006 | 01:51 PM
PIGBAIT's Avatar
what about wiring it into the overhead lighting/moon roof unit?
Old Jan 27, 2006 | 02:02 PM
portero23's Avatar
It's easy enough to wire it to the homelink mirror. There's a *very* good DIY that maps out everything you need to do. Print it out and just follow the instructions. If you wire it to the homelink mirror, it will still turn the detector on and off as well.
Also just as easily accomplished is running the cable across the headliner, down the driver's side A-pillar and into the fuse box. You can add a fuse to an existing switched fuse. I just did the install last weekend - it was a cinch!
-P23
Old Jan 27, 2006 | 02:11 PM
NgoRX8's Avatar
I got my Passport X50 yesterday and did the hardwire install.
It was easy. There is a DIY here that helps, but I chose to tap into a different wire. http://www.hi-impact.org/ryang/modif...valentine.html this is from PUR NRG.
Look at the DIY by Attack for step by step on how to access the overhead unit.
Old Jan 27, 2006 | 02:42 PM
Ranged28's Avatar
My audio shop hardwired my Passport 8500 in like 30 minutes. The wire goes up into the headliner at the windshield and you don't see it anywhere. Only problem with Passport is you have to purchase the hardwire kit which was like $35.
Old Jan 27, 2006 | 04:40 PM
NgoRX8's Avatar
35 bucks? no way. just get the direct wire cord w/o any of that special mute button. it costs $10.
Old Jan 27, 2006 | 05:05 PM
StealthTL's Avatar
Metatron
Arrow Search....
"Seek and ye shall find"
You could start with a search for the terms "radar" or "hardwire", either would take you to the DIY forum, where there are about 200 posts on the subject.
Like this one....
You're welcome.
S
Old Jan 29, 2006 | 10:30 AM
Oranje's Avatar
JM1FE
Some pics of my RX8 X50 hardwire install
Attached Thumbnails Hardwiring Radar Detector...???-radar02.jpg   Hardwiring Radar Detector...???-radar05.jpg   Hardwiring Radar Detector...???-radar06.jpg
Old Jan 29, 2006 | 11:28 AM
NgoRX8's Avatar
That is pretty neat. Looks clean. Nice Idea on putting the smart cord at that spot. If I ever had my hand there while driving, I think I'd find it every useful.
Old Feb 1, 2006 | 02:09 PM
Ledfoot's Avatar
...Hello again Officer...
Anyone using a V1 in their 8? If so, what is your setup?
Old Apr 18, 2006 | 11:57 AM
pikachu's Avatar
Thanks Oranje for the idea. This is mine
[IMG][/IMG]
thew
Audio/Video
Oct 30, 2004 05:26 PM
pghRX8
Mar 28, 2004 08:13 AM
nickax
9
Dec 17, 2003 09:46 AM
Omicron
10
Nov 29, 2003 12:43 PM
z00m-z00m
Sep 16, 2003 03:54 PM
