Problem with my steering wheel
Old Jan 25, 2006 | 11:34 AM
giova_rx8's Avatar
G & V
Question Problem with my steering wheel
Hy my name is giovanni and i need help please i don't know what to do.. i install a turbo kit on my car and now mazda dont want to see my car anymore... this is my problem when i went to hot import night last dicember i had to disconect battery and when i reconteced it my steering wheel light on the dash is always on and my sheel is tight please help my i do not know but i think that it have to be with the air pump but a lot of people saw my car and can understand what happen.. thanks you my email is giova_rx8@hotmail.com and soryy for my english i am learning it
Old Jan 25, 2006 | 11:53 AM
05whiterx8's Avatar
Director of Service
most mazda's now have electronic steering pumps, and if they lose power or are replaced they need to be reprogrammed, that may be all you have to do, but i believe that it has to be done at the dealer
Old Jan 25, 2006 | 12:18 PM
JonsToy's Avatar
Registered Rep
Try turning the wheel all the way to the left, then all the way to the right to reset the power steering module.
Old Jan 25, 2006 | 01:21 PM
ranger4277's Avatar
Cones need lovin' too!
Yeah.. it is all in the owner's manual.
Old Jan 25, 2006 | 01:23 PM
05whiterx8's Avatar
Director of Service
guess i should read the manual.....lol
Old Jan 25, 2006 | 01:34 PM
AdamK's Avatar
I just searched my OwnerManual.pdf and didn't see anything about resetting the power steering?? What page is it in your manual?? TIA
Old Jan 25, 2006 | 03:38 PM
beachdog's Avatar
look for steering angle sensor
Old Jan 26, 2006 | 01:46 PM
giova_rx8's Avatar
G & V
hi look i did the thing to turn the wheel to the left and to the right and nothing happens but the thing is that azda do not want to see my car again because i put a turbo ieven if i am going to pay for the reparation ... i do not know what to do please helppppp
Old Jan 26, 2006 | 02:17 PM
Go48's Avatar
Go to another dealer.
Old Jan 26, 2006 | 02:23 PM
AdamK's Avatar
Nothing found....
Old Jan 26, 2006 | 03:44 PM
Ericok's Avatar
Rotary Wanker
I still think your steering module needs to be reset. Disconnect your battery and wait a few minutes - that should wipe out any bad programming remaining in the module. Re-connect the battery, turn on the ignition. You should get a steering malfunction lamp. Turn the steering wheel until the wheels go ALL the way to the left, then turn the steering until the wheels go ALL the way to the right and then return the steering wheel to the center. Turn ignition off then on. It should be reset and the light should be out. If the steering is still tight, have to look for a mechanical problem: electric power to the steering rack, binding in the steering column or shaft. Can you get a trouble code from the computer?
Old Jan 26, 2006 | 05:10 PM
beachdog's Avatar
ericok, you have it backwards, it is right first (clockwise) then left (counterclockwise). These instructions refer to the DSC but also resets the power steering. p5-45 of the manual:
If the battery is disconnected, the DSC
will be inoperable. In this case, the
DSC OFF indicator light flashes and
the TCS/DSC indicator light
illuminates.
To make the DSC operable, do the
following procedure.
1. Turn the ignition switch to the ON
position.
2. Turn the steering clockwise fully,
then turn it counterclockwise fully.
3. Make sure the DSC OFF indicator
goes off.
4. Turn the ignition switch to the OFF
position, then turn it to the ON
position again.
5. Make sure the TCS/DSC indicator
light goes off.
If the TCS/DSC indicator light and the
DSC OFF indicator light remain
illuminated even after turning the
ignition switch to the ON position,
consult an Authorized Mazda Dealer.
Old Jan 26, 2006 | 05:45 PM
bd32322's Avatar
just my 2 cents from working with lame computers. After disconnecting the battery when you are following the steps posted above, reconnect it after at least a minute or two. Dont disconnect and reconnect immediately.
- Bodi
Old Jan 27, 2006 | 07:12 AM
Ericok's Avatar
Rotary Wanker
"ericok, you have it backwards,..."
I actually quoted the procedure out of the 2004 Quick Tips booklet which said left-right-center. I would guess from that the order probably doesn't matter. What the quick tips booklet REALLY says is that if the steering light remains on - dealer service is required. Giovanni's problem sounds like it could be more than just resetting the steering angle sensor but, since he said he's willing to pay for the repair himself, he should be able to find a shop willing to fix it (not sure why the dealer would refuse a PAYING customer?).
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
mesaboogie
Aug 7, 2015 10:48 AM
M RX 8
Aug 5, 2015 06:45 PM
