Chirping noise from my engine
Old Jan 21, 2006 | 10:34 PM
Rotary78's Avatar
ZOOM ZOOM ZOOM
Question Chirping noise from my engine
I have an M/T '05 8 and when i hit about 7K a while back i heard this chirping noise coming from the engine, while i was at a traffic light, and when i was driving, or when i went over bumps in the road... it sounds like a combination of a chirping noise and a squealing sound.. Now i'm at 12K and the noise came back... Now my friend has a A/T '04 and he said that he had that same problem, but some how it went away... Does anyone out there know how to get it fixed? or has had this same problem? your help is greatly appreciated... drive on
Old Jan 22, 2006 | 04:16 PM
Freddie's Avatar
Check for bird's nest under the hood? Sorry, couldn't resist.
Old Jan 23, 2006 | 08:09 PM
guy321's Avatar
Humpin legs and takin nam
Could be a loose belt, could also be engine pinging.. What octane gas do you run?
Old Jan 23, 2006 | 08:18 PM
adrian-1's Avatar
Ex- member.
That's what I'm thinking... especially since he's turbo'd. right?
Old Jan 23, 2006 | 10:52 PM
zoom44's Avatar
not ping
Old Jan 25, 2006 | 08:46 AM
Rotary78's Avatar
ZOOM ZOOM ZOOM
i always use premium with an octane of 93..... i'm starting to think that putting a turbo in my 8 was a bad move. I've had so much more problems then when it was stock.
Old Jan 25, 2006 | 08:49 AM
JonsToy's Avatar
Registered Rep
Chirping normally indicates a bad belt or a failing bearing. Check your belts and the water pump.
Old Jan 25, 2006 | 09:28 AM
Luftwaffle's Avatar
Are you positive it's coming from the engine? Next time it happens, touch your gauge cover. It took me a while to figure out what the hell was the cause of the noise.
Old Jan 25, 2006 | 12:22 PM
adrian-1's Avatar
Ex- member.
It's all in the tuning.
Depending on how old your kit it is, you may need the extra dongle released by Greddy. Also, if your car has the R-flash, that may also be your problem. I ditched the emanage for the Interceptor X and that fixed alot of my problems.
Again, this is if it's detonating due to the untuned map.... it could be something else. Did you expect not to run into any problems after buying the 1st turbo kit available for the RX8?
My Greddy turbo has been running so well at 10psi that I'm thinking of upgrading to a bigger turbo.
Old Jan 25, 2006 | 08:49 PM
Budweiser8Jr's Avatar
I have noticed a few noises coming from my car as well, 1200 miles on it.
At WOT, right around 8K, it makes a buzzing sound in the front end, like a spun bearing or something.
Secondly at any speed, shifting into 4th only, I get a chirp....
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
PTQLam
Aug 16, 2015 05:40 PM
Belalnabi
Jul 17, 2015 07:48 PM
