Rotary78
01-21-2006, 11:25 PM
I have an VR '05 8, with a OBX Cat Back Exhaust System, AEM CAI and a GReddy Turbo Kit... I put it on the dyno and the results were 272 HP???? is that right? shouldn't it be more? if anyone can help me i would appreciate it. ....
IZoomZoomI
01-21-2006, 11:47 PM
272 to the wheels is about above average for a greddy turbo owner provided that you're still using emanage. Hopefully you're not confusing the whp to flywheel hp.
rkostolni
01-21-2006, 11:54 PM
Those are really awesome results. Most people with your setup will only make 230-240hp. How much boost were you running?
MadDog
01-22-2006, 12:01 AM
Yep. Depends on boost and tune. I turned the boost down to 6psi when I last dyno'd. It was 233HP peak at 11 AFR. pretty conservative. 272 to the wheels would be a great number if you haven't even tuned it yet.
carbonRX8
01-22-2006, 12:14 AM
I put it on the dyno and the results were 272 HP???? is that right? shouldn't it be more? Is he actually complaining? Are you trying to hurt me? Are you?? :nono: Cause you really are causing pain to my 180ish hp a$$.
Moostafa29
01-22-2006, 01:13 AM
How much boost are you running. I think I am going to find a dynojet to go to soon. I want to see those numbers vs. the mustang. Btw, whats up with the CAI with your turbo. Do tell kind sir.
Rotary78
01-22-2006, 02:46 AM
ahahah woah no no i wasnt complaining, i was thinking that there was somethign wrong with it, that maybe it was wrong, but i'm happy with whatever i get, i'm new to the whole Rotary engine, so i dont know much about HP gains.... I wasn't expecting a lot from the GReddy Turbo Kit because i heard from people that it isn't the best one for the 8, but thats the only one i could afford :sadwavey: ...... yes i did have it tuned, but i didnt personally do it, i brought it to my friend and he did it for me because he had a 7 that was pretty modded. i was running 7 Psi during the dyno test, but it doesn't hold it for very long it definitely wasn't boosting at 7 Psi during the whole dyno run, thats why i was going to ask my friend to tune it again and make sure everything is right and then dyno it again. don't get me wrong i'll take any HP i can get.... thanks for all your help guys
8 Drivers :rock:
Moostafa29
01-22-2006, 11:17 AM
What would it drop off to? I'm wondering if here are just variances in the turbo itself, because my stock boost is like 9psi, and I can hold about 8psi to redline.
MadDog
01-22-2006, 11:24 AM
Hey Moostafa, you're running the interceptor, right? Have you done a dyno yet?
Moostafa29
01-22-2006, 03:34 PM
Just to tune with. 230whp on a mustang. Tuning was pretty conservative, and that was done with a cooled off engine at 10psi. The final high boost tune was at 12.5psi, but there was too much heat soak to get decent numbers from that.
