O2 sensor
Old Jan 21, 2006 | 11:02 AM
shawn81's Avatar
O2 sensor
OK i need help from you guys. i want to get a test P but i need to know what to do with my O2 Sensor i know there is a " chip " that sends the right signals to the ecu and tricks it i need to know if it works and if so where can i get it from ....thank you guys
Old Jan 21, 2006 | 11:27 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
There is no chip for this ecu. The ecu activly tests the cat by sending rapidly alternating lean/rich cycles through the engine and looks for signal inversion between the wideband sensor in the manifold and the sensor post-cat. If it does not see this, it throws a cel. Some say that they never get a lit cel. With OBDII you can get stored cels that will show up if you query the system, but you wont see the light.
There is one unproven system on this board using a bung extention. I cant imagine why this would work. Just live with the light.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
